marmot0
posted on 11/10/14 at 08:05 AM |
Vin number
Hi, will VOSA accept the letter I, this is what is stamped into my chassis
ReMan
posted on 11/10/14 at 08:43 AM |
More to the point will they accept your VIN?
I understood that you cannot make your own any more?
Check though just in case it's usual dvla wankiness!
[Edited on 11/10/14 by ReMan]
www.plusnine.co.uk
adithorp
posted on 11/10/14 at 09:01 AM |
No.
http://jpsc.org.uk/forum/
garyt
posted on 11/10/14 at 06:33 PM |
hi no you can not make up your own vin # if you write a covering letter explaining what you are building, its donor or parts from various sources (if
you don't mind a Q plate) and that once complete that it will require an iva test, and for this it will require a vin number. As such could you
please supply one.
send it to
DONNA KENNET,
MASET
F.D4
DVLA
Swansea
SA99 1ZZ
she will send an aknolagement and then the number with some paperwork for after the iva. hope this helps. Donna deals with these matters and it saves
it disappearing into the depths of dvla.
gary
big-vee-twin
posted on 11/10/14 at 08:08 PM |
Just got mine from DVLA it took 4 weeks
[img]
Chassis number
[/img]
http://www.triangleltd.com
