Author: Subject: k series replacement
lugo35
posted on 13/10/14 at 08:26 PM Reply With Quote
hi all is there an engine that will replace the rover k lump without to much bother?
thanks andy
posted on 13/10/14 at 09:23 PM Reply With Quote
thanks andy
Another K series
owelly
posted on 13/10/14 at 09:58 PM Reply With Quote
An A-series?
http://www.ppcmag.co.uk
steve m
posted on 13/10/14 at 10:22 PM Reply With Quote
A Crossflow
DIY Si
posted on 13/10/14 at 11:20 PM Reply With Quote
A VVC K series?
Sun Tzu, The Art of War
Badger_McLetcher
posted on 14/10/14 at 06:09 AM Reply With Quote
A duck?
Sorry, gratuitous Monty Python reference.
Short answer: No, not as far as I am aware.
If disfunction is a function, then I must be some kind of genius.
r1_pete
posted on 14/10/14 at 07:27 AM Reply With Quote
I guess it depends what gearbox you are using and what bellhousings are available, if its a Type 9, the Zetec / Duratec / pinto / crossflow / Vauxhall 16v (cant remember the designation)
liam.mccaffrey
posted on 14/10/14 at 07:40 AM Reply With Quote
see u2u
Build Blog
Build Photo Album
rayward
posted on 14/10/14 at 05:38 PM Reply With Quote
someone i knew put a T16 engine in place of a k series ,not sure how much work was involved but can get some more info you want ?
Ray
posted on 14/10/14 at 06:12 PM Reply With Quote
T16 is great strong engine but nearly 50kg heavier than the K16.
ettore bugatti
posted on 14/10/14 at 10:04 PM Reply With Quote
SIAC N-series?
Ugg10
posted on 14/10/14 at 10:20 PM Reply With Quote
Obvious like for like would be the zetec se/sigma or the 4age (small revvy light engines around the 130-150hp mark) but both a lot of hassle for not a lot extra. I would stick with a vvc k series, all anciliaries would just swap over, need a couple of wires for the vvc control or go aftermarket ecu and tbs for 180hp.
[Edited on 14/10/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
wylliezx9r
posted on 15/10/14 at 09:28 AM Reply With Quote
There's a later turbocharged K-series used on Rover 75's that's what I'd go for.
George Best
