Author: Subject: PWS Loom
alland3851
posted on 19/10/14 at 04:51 PM Reply With Quote
PWS Loom
I am using a PWS Sierra loom to wire up a 7 type car based on the ford sierra. The loom does not seem to have connections for an ignition relay. Is this normal ?
I am fitting an ignition switch with separate bush button start. Would fitting a relay be advisable ?
Thanks Allan
turnipfarmer
posted on 19/10/14 at 07:09 PM Reply With Quote
Can't answer the second question, but as to the first - yes it is normal - the PWS loom doesn't use an ignition relay.
alland3851
posted on 19/10/14 at 07:28 PM Reply With Quote
Thanks for the quick reply. One problem solved ! (one of many probably).
