Author: Subject: Which gasket sealent for sump seal?
cortez
posted on 22/10/14 at 01:43 PM Reply With Quote
Just fitting a new sump seal to my Black Top Zetec. It's a scholar lowline sump so has the older Silver Top Zetec seal.
I've always used Hylomar Blue but wonder what others used and would appreciate some opinions please? Especially for the sump job that I'm about to undertake.
leon51274
posted on 22/10/14 at 01:51 PM Reply With Quote
I used Loctite SI5980 Gasket maker/sealant, seems to of worked a treat on my zetec sump.
Paul Turner
posted on 22/10/14 at 02:09 PM Reply With Quote
With the Scholar sump of a Blacktop you only need 4 tiny blobs of sealant, where the gasket crosses the joint between the front and rear covers. here there is a tiny step, just seals that.
I used ordinary black engine silicone. Been there 5 years and all OK.
No need for loads of sealant like there is on some engines. The seal works on a Zetec just as Ford intended.
cortez
posted on 22/10/14 at 03:29 PM Reply With Quote
Hi Paul
Thanks for that but I'm unsure where said blobs need to go! Can you be a little more precise with blobbing points please?
Scholar sump
Scholar sump
[Edited on 22/10/14 by cortez]
Paul Turner
posted on 22/10/14 at 03:46 PM Reply With Quote
Where the 4 black blobs are. But just a small amount.
cortez
posted on 22/10/14 at 03:53 PM Reply With Quote
Nice one...................Thanks fella!
edthedrummer
posted on 22/10/14 at 06:15 PM Reply With Quote
Threebond engine sealant, or in a different guise, hondabond from honda is pretty much the best thing since sliced bread.
