Author: Subject: Fireblade 893 running rich of lean on two cylinders
tompat3463
posted on 9/11/14 at 01:35 PM Reply With Quote
Hi guys.
I'm nearing completion of my fireblade mini project and I'm having some issues with the engine.
Even when it's just idling the left two headers (looking at the headers ) are heating up very quickly while the right two take a few minutes to warm up to running temp. I'm not sure which ones are right although I oressune the left 2 shouldn't be heating up as quick as they are.
The problem seems to be resulting in rough running and a nasty sounding idle
Could this be carbs 1-2 being out of sync with 3-4 or is this a mixture issue ?
Any help greatly appreciated
CosKev3
posted on 9/11/14 at 02:05 PM Reply With Quote
Have you stripped carbs and cleaned all the jets/air correctors etc?
Also check all your mixture screws are unscrewed the same amount
tompat3463
posted on 9/11/14 at 02:15 PM Reply With Quote
The carbs were cleaned not so long ago when I out the engine together.
Which are the mixture screws ?
CosKev3
posted on 9/11/14 at 05:38 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=108172&page=2
Got a R1 eng myself, so don't know offhand.
But a quick search reveals the thread above.
Pic of mixture screws and how many turns out they should be as a base setting
tompat3463
posted on 9/11/14 at 08:18 PM Reply With Quote
Just checked the mixture screws and they all seem in the same ballpark so I'm eliminating them now
I have a set of balancing gauges just need some of those little spigots tgat screw into the head then I'll ballance the carbs and see if this helps
mackei23b
posted on 10/11/14 at 10:41 AM Reply With Quote
Yes I would definitely get the carbs balanced and go through all the basics first.... the bleed screws will only have in impact at low throttle and should not affect the mixture at WOT.
Have you pulled out the plugs to look at the colours?
A Gunsons color tune will also let you see what is happening in the cylinders, but the colour of the plugs should also give an indication.
Ian
Jenko
posted on 10/11/14 at 12:29 PM Reply With Quote
Look at the things that are common to the two cylinders - Not sure on coil packs, but usually, the carbs are individual, so balancing should be high on the list. The central balance screw may need adjusting, balancing is important for smooth running.
Things being in the 'same ballpark' may not cut it, it need to be spot on really to iliminate issues.
MY BLOG - http://westfieldv8.blogspot.co.uk/
tompat3463
posted on 12/11/14 at 08:41 PM Reply With Quote
Hi guys. Just an update and a bump as I still haven't getten this sorted. I've narrowed this problem down to a misfire on cylinder 2. Pulled the ht lead while the engine is running and there is no chance in engine when idling when I pull out the lead on #2.
I've checked for a spark on this cylinder and its sparking well with the plug out and against an earthed part of the engine so it's not a spark or plug problem.
My question is now. Could a blockage in #2 carb be so severe as to cause a misfire ? I'm guessing yes as I've had the carbs apart before and they are so delicate.
Where should I be looking for blockages ? And what things that could be adjusted inside the carb fix this ?
Also to reply to please helpers on this thread. The carbs are now balanced and mixture screws are set at 2 and 3/4 out from closed (I'm presuming closed is fully screwed in ?)
Thanks peeps
BaileyPerformance
posted on 12/11/14 at 08:58 PM Reply With Quote
Was the plug from number 2 wet?
CosKev3
posted on 12/11/14 at 09:02 PM Reply With Quote
Is the spark plug dry when you remove it after its been running,or soaking wet in fuel?
Total blockage somewhere would cause it to misfire,likewise if its flooding with fuel it would misfire.
If the plugs totally dry I would try putting a small amount of fuel in through the intake(butterfly)when the engines running and see if the misfire goes while the eng uses this fuel.
As for cleaning you need to look through every jet in the carb and check its clear,air line is best,but thin welding wire can be good too.
tompat3463
posted on 12/11/14 at 09:10 PM Reply With Quote
Thanks for the reply mate. I've pulled the carbs off and had a look and all seems fine however what your saying is right. The spark plug is bone dry. So I'm thinking total blockage.
I have however just broke one of the mixture screws and it's totally closed ! Gutted ! Don't know how I'm going to get that out !
I'll have s better look tomorrow with the air line as you say and hope fully find something
davidimurray
posted on 12/11/14 at 10:40 PM Reply With Quote
Air line won't necessarily get everything clean.i learnt the hard way!take all the jets out and soak in carb cleaner overnight.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
tompat3463
posted on 13/11/14 at 08:41 AM Reply With Quote
After taking off the carbs and inspecting all seems fine although the I couldn't find my carb cleaner. Anyways, took off the float and again everything looks good. I'm getting some carb cleaner tonight and will thoughry clean that carb.
Like mentioned before the cool and spark seems fine so I'm 90% sure this is a fueling issue.
I also noticed last night whist the engine got up to running temperature that there is oily fluid and what looks like either vapor or smoke (hard to tell) coming from the rocker cover breather pipe. Is this normal ? I know I should have a little filter on it but I thought it was just a little odd. The smokey stuff coming out is very smelly. Almost like exhaust gas.
Can anyone else shed light on this ?
Thanks Alan
BaileyPerformance
posted on 13/11/14 at 10:04 AM Reply With Quote
Thanks Alan
If i was you i would compression test the engine before you go any further.
Do the test at full thottle
tompat3463
posted on 13/11/14 at 12:09 PM Reply With Quote
I've just put the carbs back on and sealed the plugs around and tgat seams to have done it. Engine running well and revving up and down very smooth.
Most probably a small block somewhere in the carb.
Still got the vapor coming from the rocker breather which is worrying
