Author: Subject: Excel String help needed
Ivan
posted on 12/12/14 at 08:21 AM Reply With Quote
I have an excel cell with the following string in it:
8.3.1 PSA 8.3.1 PSA 8.21
I nee the string to look like this in the single cell and to stay the same if column width changes so adding spaces between doesn't work.
8.3.1
PSA 8.3.1
PSA 8.21
Can anybody help?
Ivan
posted on 12/12/14 at 08:25 AM Reply With Quote
Ok - found the answer - Place curser in right place and hit AltEnter.
Naffa
posted on 12/12/14 at 08:26 AM Reply With Quote
Alt + Enter should put text on a new line for you in the same cell.
minitici
posted on 12/12/14 at 09:20 AM Reply With Quote
...and on a mac running Excel use
ctrl+ alt+ enter
JMW
posted on 12/12/14 at 09:46 AM Reply With Quote
You could also format the cell(s) to wrap text, but then excel will decide where to break rather than you based on the new column width. It will still try to use space as the obvious crlf point but that may not suit, as I notice in your example you split on some spaces but left others.
