Author: Subject: Car covered in damp in garage
madteg
posted on 17/12/14 at 08:18 PM Reply With Quote
How can I stop it, every night I go in its covered in damp. Don't know if should leave a heater in there or just cover the car, come on lets have some ideas.
JAMSTER
posted on 17/12/14 at 08:26 PM Reply With Quote
maybe some thing like this i have seen them for cars
Vac Bag Dry Motorcycle Vacuum Seasonal Storage System Jumbo Cover 3.6m x 2.4m
posted on 17/12/14 at 08:27 PM Reply With Quote
Have you got any insulation ? Leaks? Or ventalation? A dehumidifier may help. One of my neighbours has an inflatable garage that keeps his car dry and mould free. Had problems with mould when my garage roof was replaced a couple of years ago, cured it by fitting a couple of vents in the door, no problems since
mark chandler
posted on 17/12/14 at 10:07 PM Reply With Quote
Sounds like lack of ventilation to me, get the air moving around
Nickp
posted on 17/12/14 at 10:13 PM Reply With Quote
+1 you need to get the air moving. I built a block garage with a tin roof (insulated) but envisaged damp problems so installed an extractor fan. It's on a timer and comes on for 15mins every 2hrs and it's nice and dry in there
whitestu
posted on 17/12/14 at 10:14 PM Reply With Quote
+1
Leave the door open!
madteg
posted on 17/12/14 at 10:25 PM Reply With Quote
Thanks will sort some ventilation out at the weekend.
dhutch
posted on 18/12/14 at 12:55 PM Reply With Quote
From whats said, unless you have a lot of water coming in, I think its ventilation that's the issue.
Even if you have a lot of water coming in, unless you can stop it, the solution is still ventilation. More the better really.
You wont solve that with a dehumidifier or heater unless you are prepared to hose a hell of a lot of electric into it, and you shouldnt be!
Daniel
[Edited on 18/12/2014 by dhutch]
Mr Whippy
posted on 18/12/14 at 01:04 PM Reply With Quote
yip lack of airflow, get some air brick vents and fit them to the side that gets the most wind and the opposite side
I have a carport on the side of my garage and due the obviously great flow of air through it almost mummifies any car put there
