Author: Subject: Pinto power increases
posted on 24/11/04 at 10:23 AM Reply With Quote
What's the most effective route to gettting more power from standad Pinto?
The engine has been fully rebuilt with a new oversize pistons (2096cc I think), rings, bearings, valves and a standard profile camshaft. The carb is a Weber 32/26 manual choke with standard electronic ignition (Bosch/Motorcraft).
Would a performance camshaft be the best place to start or are there any other areas to adddress first?
Nick
Bananaman
posted on 24/11/04 at 11:07 AM Reply With Quote
I fitted a pair of 40's and a performance cam, and Iam well happy with the performance of my Xtreme. Iam getting 150 BHP at the wheels.
Michael
Rob Allison
posted on 26/11/04 at 03:12 AM Reply With Quote
A Garrett T3
jacko
posted on 26/11/04 at 06:06 PM Reply With Quote
pinto mods
Hi Nick i would suggest getting a book could how to power tune ford sohc "pinto and cosworth dohc engines" by Des Hammill and read it cover to cover its a very good read i hope this helps you jacko
fester
posted on 26/11/04 at 06:22 PM Reply With Quote
pinto power
I'm with Jacko on that one,good book.Rob reckons a Garret T3 , check out www.turbofast.co.au for the Ray hall site ,click on "turbo calculators",Then "turbo match" ..Good fun
posted on 27/11/04 at 05:34 PM Reply With Quote
Michael
With a standard head? Getting a genuine 150bhp at the flywheel is possible with a well ported head and decent cam, but much more than that starts to get very expensive for a N/A engine.
tractorboy
posted on 27/11/04 at 10:03 PM Reply With Quote
ive got a standard 2 ltr fitted with twin 40's and im getting 146 bhp on a rolling road . believe me its quite quick enough to scare the pants off you !!!!!!!
Avoneer
posted on 27/11/04 at 10:10 PM Reply With Quote
I've got a 2ltr with fast cam and twin 45's. Not rr'd yet, but fast enough for me and not much that'll play with you from the lights.
Pat....
posted on 28/11/04 at 11:14 AM Reply With Quote
That will be a flywheel power reading though, using the guestimated transmission loss.
DCOE's are good, but gaining somewhere between 31-41bhp odd over stock seems remarkable, especialy as the stock DGAV carb is good for up to 140bhp.
Bertie basset
posted on 30/11/04 at 03:43 PM Reply With Quote
mmmmm, if you can get 150 at wheels on 40's and a cam i'll have a dozen please.
stephen_gusterson
posted on 30/11/04 at 05:22 PM Reply With Quote
30% or so more power just from a carb change seems suspect......
atb
steve
greggors84
posted on 30/11/04 at 07:27 PM Reply With Quote
Rolling road figures always seem a bit suspect to me. Good for comparing cars or mods but not good for giving reliable power outputs, especially at the fly.
Also depends how the operator measures the fly figure, most use the coast down calcs, but ive heard of some just using a simple formula.
Got a 2.1, large valve ported head, fast road cam (i think) and twin 45s.
I bought the engine as it is, as i wanted something i could just drop straight in and was told it was around 150-160 at the fly but i dont know how this was measured. I think he may have been going off what people have got with similar mods.
Chris
The Magnificent 7!
Bananaman
posted on 1/12/04 at 09:48 AM Reply With Quote
Whoops! I think that I may have unibtentionally misled a bit here. The head has been worked on, ports, valves, valve seats, compression, etc.
It's still quite quick though, even it it's in a heavier stainless chassis with a slightly portly driver!
I have to agree about rolling roads and dynos, the performance figures all depend on the operator.
Michael
[Edited on 1/12/04 by Bananaman]
