Author: Subject: Scooter performance question
smart51
posted on 23/12/14 at 03:53 PM Reply With Quote
I've noticed a reduction in acceleration off the line from my scooter engined trike. Once you've got going it's fine. What might cause this? If the V belt was worn, would it do this? Perhaps it can't get the lowest "gear" any more.
posted on 23/12/14 at 04:55 PM Reply With Quote
Gunk in the rollers? Belt would have to be well stretched to cause it.
Check the rollers and ramps are nice and clean and free first.
on_eighty_runner
posted on 23/12/14 at 06:31 PM Reply With Quote
I had a Gilera Runner 180 and extended motorways use did cause the clutch to get too hot and the friction material to become glazed over. A gentle sanding did sort it out but always came back!
Extra weight if the trike makes the clutch more likely to slip, more heat, more slip, more heat.....
smart51
posted on 23/12/14 at 07:08 PM Reply With Quote
It's only when pulling away. Once I get over 20 MPH or so, everything is fine. If it was clutch slip, I'd expect to see higher revs.
There is some extra weight though. It's like having a permanent pillion rider. Nothing more than it should be able to cope with, but more often than usual.
[Edited on 23-12-2014 by smart51]
RichN
posted on 23/12/14 at 08:38 PM Reply With Quote
I've just had the belt and rollers replaced on my daily rider scooter and it has made a huge difference to pulling away, it has a lot more "go".
This is after only 6500miles and nearly 3 years of commuting.
