<<  1    2  >>
Author: Subject: Duratec Ignition Map
flak monkey
posted on 2/1/15 at 08:36 PM Reply With Quote
You will be able to safely run 30-34deg advance when cruising - if you know what load/rpm sites that fits in with you can change them now. If not you need to datalog a bit and then make some adjustments.
Sera
http://www.motosera.com
davidimurray
posted on 2/1/15 at 10:07 PM Reply With Quote
Thanks Flak
Will wait until I get it on the road and then see where I am cruising
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
BaileyPerformance
posted on 3/1/15 at 11:34 AM Reply With Quote
A duratec needs at least 28deg but no more than 32, all in after 4000RPM to be safe, so best increase your table abit.
I suggest 28 at 4000, 32 at 7000
davidimurray
posted on 3/1/15 at 06:43 PM Reply With Quote
Thanks Bailey - your hep is much appreciated. I've tweaked as per your reccomendations.
Dave
<<  1    2  >>
