Author: Subject: FS: Carbon RAM Air Intake + Fitting Plate
Barkalarr
Contributor
Posts 932
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 6/1/15 at 03:53 PM Reply With Quote
Carbon RAM air intake to cut down induction noise on track days.
£200 delivered to UK will post abroad at cost.
dimensions :
Fitting plate is blank. Airbox has no holes drilled in it either.
welderman
posted on 6/1/15 at 04:23 PM Reply With Quote
So there is only the air filter hole cut in it
Thank's, Joe
I don't stalk people
Barkalarr
Contributor
Posts 932
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 6/1/15 at 04:35 PM Reply With Quote
Yes, there's the hole at the bottom which bolts onto the alloy plate, and the ram air hole which hangs out the bonnet.
There are no other mounting holes (it's new)
Barkalarr
Contributor
Posts 932
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 6/1/15 at 04:37 PM Reply With Quote
This is what it's intended for...
welderman
posted on 6/1/15 at 04:59 PM Reply With Quote
that looks nice
Thank's, Joe
INDY BIRD
posted on 6/1/15 at 06:25 PM Reply With Quote
Same as this and a very nice airbox, I fitted one to the striker see pic,
raw striker airbox
raw striker airbox
[Edited on 6/1/15 by INDY BIRD]
Tobz24
posted on 19/4/20 at 11:08 AM Reply With Quote
Carbon ram intake
dimensions :
Hi, I see this post was some years ago, I'm currently building one for my dunnells silvertop Zetec, is this product still available to be built/purchased?
Barkalarr
Contributor
Posts 932
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 19/4/20 at 11:23 AM Reply With Quote
I still have the mould but it’s a bit knackered.
I can certainly make one but can’t guarantee it will be mint.
J90rdn
posted on 21/4/20 at 09:06 AM Reply With Quote
Might also be interested, dependant on price. Either carbon or fibreglass would be fine, if fibreglass brings price down even further.
Barkalarr
Contributor
Posts 932
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 21/4/20 at 01:23 PM Reply With Quote
I will revert with prices...
RussH
posted on 21/4/20 at 07:46 PM Reply With Quote
They look great. Also interested in the cabbage cannon!
Do they fit over the air filter, in which Case would I need a certain one? Thanks!
Duratec Westfield
wowblaauw
posted on 21/4/20 at 10:39 PM Reply With Quote
Excellent, does the cabbage cannon including heat or movement seeking sights? 😁
I’m interested - pricing and availability please.
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
StuP
posted on 22/5/20 at 08:22 PM Reply With Quote
I'm also interested in this
