Author: Subject: Fuel Pump Question,
ian.stewart
posted on 10/1/15 at 09:05 PM Reply With Quote
Fuel Pump Question,
On my 4age, I running 40 DHLAs, I dont expect to put out any more than 140hp, BUT, I haven't run carbs on an engine for nearly 25 years, all have been either TJ mechanical injection or Jenveys,
I would think the options on electric pumps is still basically the same, anything to avoid, or what is recommended
Something different, Very different..............
r1_pete
posted on 10/1/15 at 10:46 PM Reply With Quote
I've been running one of these on my 4.2 e type for 5 years or so with no problems:
MGB FUEL PUMP
ian locostzx9rc2
posted on 11/1/15 at 11:05 AM Reply With Quote
Low pressure pump and fuel regulator to get pressure down to 3psi
mk85
posted on 11/1/15 at 02:06 PM Reply With Quote
I have a brand new fuel pump from car builder solutions if you want. I purchased it just for the hanger that it came with
ian.stewart
posted on 11/1/15 at 02:49 PM Reply With Quote
Tell me more, The only pump I could find on CBS a PI pump.
mk85
posted on 11/1/15 at 05:10 PM Reply With Quote
http://www.carbuildersolutions.com/uk/in-tank-fuel-pump-45psi
it's that pump. But i basically wanted the hanger and the outlet for the tank.
ian.stewart
posted on 13/1/15 at 08:10 PM Reply With Quote
Hi, Thanks for the offer, Im thinking that will struggle to run my carbs @3psi, not because it cant cope with the demands, but it will never get the fuel flow thru it to keep it cool and deliver warm fuel to the carbs as I am not running a return line
907
posted on 13/1/15 at 08:47 PM Reply With Quote
I run Delorto 45's with what is basically a high output electronic version of the Moggy 1000 pump.
No need for a regulator.
It ticks fast when filling the float chambers then slows to an occasional tick when they are full.
Can't really hear it once on the road, but then I have my own exhaust fitted.
I find it reassuring when I can hear something working.
Paul G
pump for Del 45's
pump for Del 45's
[Edited on 14/1/15 by 907]
Paul Turner
posted on 14/1/15 at 09:07 AM Reply With Quote
That pump is no good for carbs. Its an injection pump.
I used a Facet silvertop pump on my x-flow for 11 years with no issues. When I fitted to Zetec I replaced it with a redtop to ensure there was sufficient fuel and when I went injuection I retained the redtop as a lift pump. Been in 13 years now and still fine.
With 140 bhp one of these should be fine with a regulator.
http://www.glencoeltd.co.uk/facet-fuel-pumps/facet-cylindrical-pump-12v-24v/facet-silver-top-competition-cylindrical-fuel-pump-kit/
When I had carbs I used a sytec regulator from the same place.
Some say that both can be unreliable but I have never had an issue myself or met anyone who has.
Still got the silvertop. Where are you?
[Edited on 14/1/15 by Paul Turner]
