Author: Subject: remote gearchange for ford 4-speed box (not T9!!)
alfas
posted on 18/1/15 at 10:41 PM Reply With Quote
i´m searching a remote gearchange for the ford 4-speed boxes with the following type of lever:
[Edited on 18/1/15 by alfas]
trialsman
posted on 18/1/15 at 11:13 PM Reply With Quote
This is what I found http://www.locostbuilders.co.uk/viewthread.php?tid=136639 I wish there was a better way to get around the reverse detent. Russ
alfas
posted on 18/1/15 at 11:35 PM Reply With Quote
i need something for buying as my fabrication-skills are limited.
do i understand right: there are 2 options for the reverse:
no reverse
or reverse selectable, without any inhibitor?
trialsman
posted on 18/1/15 at 11:40 PM Reply With Quote
Yes but he didn't go into detail on how and where the reverse detent was.
Trollyjack
posted on 19/1/15 at 08:31 AM Reply With Quote
It can be done
I'll take a photo of mine
lots of the Locost Racers use the 4 speed and quite few differant idears
TrollyJack
phil m
posted on 19/1/15 at 10:30 AM Reply With Quote
Hi
This is the reverse peg that's comes out. . It's a pretty easy job to remove it. With regard to reverse, I made a gate out of Ali to ensure that I don't accidently engage revers. t his sits under the gear stick gaiter out of view
[/img]
alfas
posted on 19/1/15 at 12:23 PM Reply With Quote
where does this "reverse peg" sit?
phil m
posted on 19/1/15 at 07:15 PM Reply With Quote
With gear out stick out of situ, you can it through the aperture looking towards the back of the box. To remove it you remove the blanking disc at the back of the box and using a narrow bar through the gear stick aperture, tap it out . A little awkward but quite straightforward
alfas
posted on 19/1/15 at 10:58 PM Reply With Quote
does modifying the fork on the lever hasnt the same effect?
alfas
posted on 22/7/15 at 11:06 PM Reply With Quote
i´m still searching such a remote lever....but there must be a device fitted that i cannot select the reverse.
Trollyjack
posted on 23/7/15 at 02:25 PM Reply With Quote
I will post a photo when i get back off holliday
TrollyJack
