Author: Subject: Handbrake on live axle
cb500t
posted on 24/1/15 at 04:21 PM Reply With Quote
I will be running a Mk1 Cortina axle on my build ,but its handbrake is rod actuated,and Sods Law means the rod is right where I need to place a Panhard rod,is there a cunning way round this situation ( a tried and trusted fix ?? )
View User's Profile E-Mail User View All Posts By User U2U Member   cb500t 's Aim
steve m
posted on 24/1/15 at 04:29 PM Reply With Quote
Yep, move the back plates around and drill new holes to suit, as its a common problem
steve
cb500t
posted on 24/1/15 at 04:36 PM Reply With Quote
So the trick is to rotate the backplates and drill new mounting holes? But the rod passes through a 'boss' on the axle,do you just ignore it?
NigeEss
posted on 24/1/15 at 05:57 PM Reply With Quote
Can you cut the boss off and re-position it ?
Oldaker
posted on 24/1/15 at 08:15 PM Reply With Quote
The Ron Champion answer was to use Allegro handbrake cables, I believe, and do away with the rod system
[Edited on 25/1/15 by Oldaker]
twybrow
posted on 25/1/15 at 09:32 AM Reply With Quote
Originally posted by Oldaker
The Ron Chapman answer was to use Allegro handbrake cables, I believe, and do away with the rod system
This is what my axle has. All of the rod mechanism removed, and a bracket welded on to mount the Allegro cables. I haven't even needed to rotate the back plates....
cb500t
posted on 25/1/15 at 09:39 AM Reply With Quote
Any pics? and Allegro cables seem to come in 2 parts.do I need both?
Oldaker
posted on 25/1/15 at 09:48 AM Reply With Quote
Separate cable to each drum Best pic I can find: http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=a758270-P1010052.JPG
and : http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=a758639-P6170017.jpg
cb500t
posted on 25/1/15 at 09:50 AM Reply With Quote
Both 'rear' cables or both what are described as 'front' cables?
Oldaker
posted on 25/1/15 at 10:36 AM Reply With Quote
I've not got the book to hand, but I think it is the 2 rear cables
Edit: found a link with part numbers : http://www.locostbuilders.co.uk/viewthread.php?tid=37959
Danozeman
posted on 25/1/15 at 10:45 AM Reply With Quote
Im running cortina back axle with cables. Much better than the rod.
Dan
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
steve m
posted on 25/1/15 at 12:46 PM Reply With Quote
"Im running escort back axle with the original rods and cables, works fine for me"
