Author: Subject: 4 point or 6 point Black TRS HANs Harnesses (FIA: 2018)
yellowcab
posted on 26/1/15 at 06:00 PM Reply With Quote
Selling the harnesses from my Spire GT3
HANs compatible
Single Seater style 5th & 6th point
Aircraft style buckle
5th & 6th point optional
£100.00 or offers
http://www.trs-motorsport.com/harnesses-fia-approved-harnesses-hans-only-harnesses/trs-harnesses/magnum-superlite-6-point-single-seater-hans-only_ct49 9bd190pd1603.htm
Gumph from their website:
FIA approved 50mm / 75mm 6 point Superlite single seater HANS ONLY harness with alloy adjusters on the shoulder straps
• FIA approved 8853/98 Single Seater Harness
• 6 point bolt-in fixings
• 50mm upper shoulder HANS ONLY
• 75mm lower shoulder and lap straps
• Alloy adjusters on shoulders
• HANS ONLY
Top of the range 50mm HANS ONLY, FIA 8853/98 approved single seater harness.
It has smooth running alloy adjusters with bolt-in fixing plates on the shoulders and bolt-in pinch plates on the lap and crutch straps. The upper shoulder measurement from the fixing on the chassis to the adjuster on the driver's chest is 41cm. If you require a different length shoulder strap please use the attached bespoke specifcation sheet when ordering.
TRS' light weight 140 gram quick release buckle is of composite construction and is attached to the crutch strap on 6 point harnesses. Innovative features such as, a securing tab for intercom cables on the shoulder strap, thumb loops on lower shoulder straps and Velcro patches on lap straps were all pioneered by TRS and are standard on all of our competition harnesses.
