Author: Subject: K series rwd conversion parts
matty h
posted on 9/2/15 at 09:31 PM Reply With Quote
I am looking for parts to fit a k series engine for rwd.
Parts I think I need are
Bellhousing including starter motor spacer and clutch.
Wet sump
Exhaust manifold long primarys
Anything else I might need.
Let me know what you have.
Matty
lsdweb
posted on 10/2/15 at 08:26 AM Reply With Quote
Hi Matty
I have a Caterham flywheel and possibly clutch.
Let me know if you're interested.
Regards
Wyn
garybee
posted on 10/2/15 at 10:15 AM Reply With Quote
I have pretty much everything required for this and am located in Lincolnshire too.
In workshop at the mo:-
Bellhousing
release fork
starter spacer
long and short Caterham manifolds
exhaust with cat
water rails
etc. etc.
Haven't thought about prices as some of it is spares for the race car but I do have a habit of keeping too much so am open to the thought of a bit of garage clearing.
[Edited on 10/2/15 by garybee]
matty h
posted on 10/2/15 at 07:52 PM Reply With Quote
U2U's sent
Matty
matty h
posted on 3/3/15 at 09:30 PM Reply With Quote
Still looking for a wet sump andstarter motor.
Regards Matty
Westy K
posted on 4/3/15 at 12:03 AM Reply With Quote
When I first fitted a fitted a K series in the Westfield I used a standard early tin sump without any issues.
I even used the car for sprinting.
Really dose depend on how much ground and bonnet clearance though. It was just about acceptable on mine (ground Clearance wise) but I wouldn't of wanted it any lower.
If you have to fit the Caterham wet sump have a good search through the posts on Blatchat. They seem problematic at best for anything other than road use but there are some mods that can be done to the gasket and an Apollo tank (a kind of swirl pot) is a must.
Starter motor wise I gave up trying to find a standard one form another car to fit after trying all sorts that were listed and ended up biting the bullet and buying one from Caterham.
Nice compact bit of kit though.
Sorry Don't have any bits to sell but hope this helps.
Ian
[Edited on 4/3/15 by Westy K]
matty h
posted on 20/3/15 at 06:48 PM Reply With Quote
Stil need a starter motor.
No the part numbers but seems there are two different motor body sizes.
Anyone got a suitable starter.
Regards Matty
matty h
posted on 26/3/15 at 09:17 PM Reply With Quote
Still want a starter motor.
Matty
matty h
posted on 13/4/15 at 08:49 PM Reply With Quote
Still need starter motor will have to bump the car off at this rate.
Matty
