Author: Subject: MX-5 Engine compatibility
clutch_kick
posted on 16/2/15 at 10:48 AM Reply With Quote
Don't know where would be a reliable source to look but I need to know if a '95 1.8 engine parts would be compatible with a '00 engine?
My Donor is a '00 model MK2, 1.8 ltr and I was offered a '95 1.8 engine that's knocking a little for a very silly price, so it would be an ideal rebuild project on the side. So I was wondering ... will it fit the Gearbox, Engine mounts, wiring loom ( I am planning to run a Megasquirt), and instruments, etc?
pewe
posted on 16/2/15 at 12:19 PM Reply With Quote
As far as I know engine mounts, gearbox etc. are all the same.
Wiring loom should also be the same/similar - give or take the possibilty of ABS, air con etc.
Unusual for the engine to be knocking.
The bottom ends are certainly very strong.
For the sort of money a rebuild will cost and the price known engines are fetching I'd be looking at buying an engine which runs OK.
Best source for info is probably miatanet though there's a fair amount on Nutz.
HTH.
Cheers, Pewe10
clutch_kick
posted on 16/2/15 at 12:31 PM Reply With Quote
Slimy38
posted on 16/2/15 at 01:17 PM Reply With Quote
Agreed, it does appear the standard rebuild parts actually work out quite expensive, compared to the ease of getting a working engine.
ianhurley20
posted on 16/2/15 at 09:24 PM Reply With Quote
I bought a mk 2 '99 car for 360, took out engine propshaft gearbox and electrics and sold the rest for 481. Seems to me the best route for getting an engine that I was able to run test and drive for a bit of labour, advertising and - 121 pounds ;-)
clutch_kick
posted on 17/2/15 at 12:11 AM Reply With Quote
Well in all honesty he's asking for 66£. Worth getting for the head alone I guess.
johnH20
posted on 17/2/15 at 09:41 AM Reply With Quote
Don't take it as gospel but I believe all Mk 2 engines are VVT. The head is different in a number of respects and I would guess the wiring loom too. As suggested above Nutz or Miata.net are your best sources of info.
