Author: Subject: Trailers and safe loading?
daniel mason
posted on 20/2/15 at 08:59 PM Reply With Quote
Is it possible to load a car on a trailer with bodywork hanging over the rear of the bed?
I'm looking at some lightweight trailers but my force is close to 14' long with massive front and rear wings.
The wheelbase is short and a 10' bed would mean if I pushed it on backwards the front wing would be hanging 6" behind the bed. But the front wheels over 18" on the bed and the rear wheels tight to the front of the bed!
[Edited on 20/2/15 by daniel mason]
posted on 20/2/15 at 09:19 PM Reply With Quote
I'd be more worried about getting the nose weight right , get it wrong and it could be a case of the tail wagging the dog
daniel mason
posted on 20/2/15 at 09:23 PM Reply With Quote
Can't do any more than push it on backwards. The car only weighs 307kg wet and there's only 55kg at each front corner of the car. Almost 100kg a corner at the rear!
owelly
posted on 20/2/15 at 09:24 PM Reply With Quote
It's legal as long as the load is 'covered' by the markers lamps and/or rear lamps. Correct weight loading is a separate issue but I guess you have that covered?!
http://www.ppcmag.co.uk
daniel mason
posted on 20/2/15 at 09:27 PM Reply With Quote
One of my concerns was visibility of rear number plate
PAUL FISHER
posted on 20/2/15 at 09:28 PM Reply With Quote
When I was doing my lgv/pcv driver cpc training, you are allowed 1m of rear over hang, without the need for any marker boards etc, I would think it would be the same for a car trailer.
daniel mason
posted on 20/2/15 at 09:49 PM Reply With Quote
It's only 6" of the carbon front wing which would overhang! Hopefully not too bad. Other than that it's a slightly larger trailer!
Ben_Copeland
posted on 20/2/15 at 10:15 PM Reply With Quote
As long as you can see the lights and number plate it should be fine.
If you have to mount a trailer board to the car so its visible, do that...
Ben
Locost Map on Google Maps
Enter Your Details Here
atm92484
posted on 21/2/15 at 02:20 AM Reply With Quote
Will the air moving backwards over the wings create enough lift to be an issue?
-Andrew
Build Log
mark chandler
posted on 21/2/15 at 08:35 AM Reply With Quote
6" overhang would not bother me.
Loads of lorries have larger overhangs than that, look tippers etc.
daniel mason
posted on 21/2/15 at 09:44 AM Reply With Quote
The car will also be covered so none of the aero components will have an effect! Cheers
mcerd1
posted on 21/2/15 at 10:48 AM Reply With Quote
You can always make up a removable extended mounting frame for a light board - this is what the do on some boat traliers
