Author: Subject: Steering Column hole in bulkhead
avagolen
posted on 21/2/15 at 05:05 PM Reply With Quote
Hi all,
Like some others on the forum, I am waiting for an IVA date.
Just looking / thinking about some aspects of my build and wonder
what the forum thinks about where the steering column goes through
the bulkhead into the engine bay.
column_bulkhead
column_bulkhead
Anyone thing this is a fail, and if so why?
Many thanks.
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 21/2/15 at 05:40 PM Reply With Quote
I used a section of c.v. joint boot for the column to come through.
theduck
posted on 21/2/15 at 06:55 PM Reply With Quote
I'm taking the attitude at the moment, if I think it could be a fail, even if I don't know why, do something to make it look better.
avagolen
posted on 21/2/15 at 07:00 PM Reply With Quote
Thanks .
The Black Flash
posted on 21/2/15 at 08:19 PM Reply With Quote
Can't think why that would fail. But you'll have a fair draft blowing over your legs, so it's probably worth covering at some point. I wouldn't stress over it though.
mark chandler
posted on 21/2/15 at 09:23 PM Reply With Quote
I,d make a card template that fits snugly over the hole, transfer to a neat bit of Ali trim to make pretty then rivit in place
If anything catches fire or a hose bursts I would not want it blowning back over my legs.
Car looks great
avagolen
posted on 21/2/15 at 09:29 PM Reply With Quote
Thanks Mark. That is exactly what I am thinking of doing.
Small nuts and and bolts though. It can be removed
as and when required that way.
907
posted on 21/2/15 at 11:01 PM Reply With Quote
Mine looks like this, and no eyebrows were raised.
Paul G
Hole in bulkhead
Hole in bulkhead
avagolen
posted on 22/2/15 at 09:51 AM Reply With Quote
Thanks Paul.
adithorp
posted on 22/2/15 at 02:21 PM Reply With Quote
I used some boot edge TRIM around the hole. I had to put some V cuts in so it didn't distort too much around the tight radius. I have a fairly tall hole as the column is height adjustable and this has reduced the amount of draft coming through. IVA might have an issue if they thought it could let too much engine bay fumes through.
[URL=http://s189.photobucket.com/user/adrianthorp/media/fury069.jpg.html][/U RL]
http://jpsc.org.uk/forum/
avagolen
posted on 22/2/15 at 03:47 PM Reply With Quote
Thanks Adi,
I like the look of you solution.
To implement it would require some careful work or column removal.
Mark, thanks for your comments. Bonnet shut line is my worst part of the car.
Once it has a few 'scars' I will have a go at improving it.
