Author: Subject: Brake/Side Lights
JamesyCottony
posted on 3/3/15 at 09:20 PM Reply With Quote
Brake/Side Lights
There are 3 wires coming out of the brake lights, does this mean they are both brake and tail lights? Obviously when brake pedal is pushed they brighten up?
gremlin1234
posted on 3/3/15 at 09:51 PM Reply With Quote
well you could take the cover off (I think a crosshead screwdriver would help) and have a look
JamesyCottony
posted on 3/3/15 at 09:54 PM Reply With Quote
It's a single buld inside, same as Land Rover Defender
gremlin1234
posted on 3/3/15 at 10:14 PM Reply With Quote
and if you take the bulb out, does it have one or two connections on the base?
or count the bulb filaments
JamesyCottony
posted on 3/3/15 at 10:21 PM Reply With Quote
I shall upload a picture of the inside tomorrow
posted on 3/3/15 at 10:23 PM Reply With Quote
Series Landrover lamps they take standard 5/21 watt double filament off set pin stop-tail bulbs, Bulb ref. type 380.
Black wire is earth, red wire 5 watt tail, green wire 21 watt stop light.
[Edited on 3/3/15 by britishtrident]
Smoking Frog
posted on 3/3/15 at 10:24 PM Reply With Quote
Put the black cable on the negative terminal of a battery try each of the other cables on the positive. I think red is sidelight and green brake.
JamesyCottony
posted on 3/3/15 at 10:43 PM Reply With Quote
Cheers guys. Will try tomorrow
