Author: Subject: Carb breathers
greavesy7
posted on 8/3/15 at 09:53 PM Reply With Quote
Carb breathers
Is it important to have pipes onto the carb breathers then fed to the front of the car or can you just connect them up to a small filter ?
[Edited on 8/3/15 by greavesy7]
CosKev3
posted on 8/3/15 at 09:59 PM Reply With Quote
Pretty sure most just leave them vent to atmosphere from what I've seen.
Could pipe them into air filter base I suppose if you don't want them open
greavesy7
posted on 8/3/15 at 10:01 PM Reply With Quote
Does it actually do anything ?
cosmick
posted on 9/3/15 at 08:05 AM Reply With Quote
Carb breathers go to the float chamber which MUST be at atmospheric pressure. Do not face them forwards into the air stream. Do not join them together as I have seen. Put them in a place where they will breath still air.
If it can't be fixed with a hammer then its probably an electrical problem.
jacko
posted on 9/3/15 at 04:35 PM Reply With Quote
Engine
Engine
Not a bike engine but zx9r carbs you can see the filter on the carbs the pipe is standard too zx9r carbs
Jacko
FASTdan
posted on 9/3/15 at 07:20 PM Reply With Quote
Joining them together is fine - most come like that as standard!
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
cosmick
posted on 9/3/15 at 07:46 PM Reply With Quote
I think there is a misunderstanding with regard to my post. Do not join together means that both sets of float chambers need to breath to atmosphere. Provided that is via a T piece, they can be joined together as long as they can still breath. I have seen people join the two pipes together so that neither float can breath. Hope this helps.
[Edited on 9/3/15 by cosmick]
kj
posted on 9/3/15 at 08:21 PM Reply With Quote
Mine open into the atmosphere no filter
Think about it, think about it again and then do it.
FASTdan
posted on 9/3/15 at 10:25 PM Reply With Quote
ah ok, yes agreed
