Author: Subject: What bushes?
Streetfighterpete
posted on 17/3/15 at 09:16 PM Reply With Quote
What bushes?
Hi Guys,
I'm rebuilding my Luego and plan to replace all the suspension bushes as a matter of course. There seem to be loads on the market (Powerflex, Superflex etc.). Any recommendations on which are the best option and what grade/stiffness to use? I plan to use the car for fun road use and maybe the odd track day. Any advice gratefully received. Cheers, Pete
posted on 18/3/15 at 06:20 PM Reply With Quote
Which ever bushes you get make sure you get the correct length crush tube , stainless would be better. Might be worth measuring the bushes , the width of the suspension arm sleeves and the width of the wishbone mounting brackets . If you haven't seen the various posts on crush tubes it's well worth doing a search. I think there might be a post by Steve Lovelock about replacement bushes? Might be a good idea to post your findings when you do find some bushes?
maccmike
posted on 18/3/15 at 06:47 PM Reply With Quote
Superpro, they have a bevelled edge which supposedly maintains rotation when worn.
posted on 18/3/15 at 08:25 PM Reply With Quote
Reply With Quote Report Post to Administrator
OK, the parts are:
Superflex Ltd, 01749 678152
SF2043P-90 Top hat bush, kit car / hot rod £3.25
SF2043-42T 19x12x42mm stainless steel tube £5.50
I realise that this isn't cheap but my car has been transformed by fitting them.
Originally posted by Steve Lovelock 23/4/11 HTH
