Author: Subject: 1.8 cvh thermostat housing?
DaveP905
posted on 19/3/15 at 06:18 PM Reply With Quote
Hi all, my first post
I'm converting my engine to run on bike carbs, just left wondering what to do about the thermostat as the housing is bolted to the standard manifold, would it be easier to use a different housing?
big_wasa
posted on 19/3/15 at 08:07 PM Reply With Quote
The stat housing from a fwd cvh should bolt on if you take the core plug out.
Surrey Dave
posted on 19/3/15 at 08:53 PM Reply With Quote
As Above
Yes FWD housing fits straight on.
AdrianH
posted on 19/3/15 at 09:47 PM Reply With Quote
Hang on there!
Yes one will fit, but before you abandon all and go for it, it has to go on the rear of the engine so check you will have enough clearance between the head and the bulkhead chassis members.
Another way out may be to cut a hole on the metal plate where the exit is to the exiting thermostat and weld in a tube and fit out to an in line stat of some type!
Adrian
Why do I have to make the tools to finish the job? More time then money.
DaveP905
posted on 19/3/15 at 10:51 PM Reply With Quote
I suppose I should have mentioned its in a sierra, so RWD.
Also I have the carbs and manifold already that has a pipe connector to use original waterway in the head.
Thanks fort the replies I'll look around
[Edited on 19/3/15 by DaveP905]
avagolen
posted on 20/3/15 at 03:22 AM Reply With Quote
I have a suitable thermostat housing for rear mounting at home if you want.
I can post some pictures early next week if you are interested.
(I nearly went CVH in my Fury - and prepared a stat housing for fitment)
Len.
DaveP905
posted on 24/3/15 at 06:14 PM Reply With Quote
Sorry peeps, forgot I posted here!
I've got hold of an inline thermostat and housing to try now, thanks though
