Author: Subject: WTD: Help bending 19mm mild tube
ChrisLeary
posted on 24/3/15 at 11:31 AM Reply With Quote
Morning,
Would anyone be able to put a nice bend (90 degrees) into a piece of 19mm mild steel tube please?
I can send dimensions and stuff over if you can u2u please.
Cash waiting!
Cheers.
Don't force it! Get a bigger hammer...
liam.mccaffrey
posted on 24/3/15 at 12:03 PM Reply With Quote
Yes I can, I have a protools Tube bender with a 0.75" die
This is 0.75" tube
top bone
top bone
[Edited on 24/3/15 by liam.mccaffrey]
Build Blog
Build Photo Album
bi22le
posted on 24/3/15 at 12:32 PM Reply With Quote
This is 0.75" tube
top bone
top bone
But is that you?!?
Always curious tto see what LCB look like.
Please read my ring story:
Marcos Controls
posted on 24/3/15 at 12:57 PM Reply With Quote
No problem, I've got a very nice electronically controlled pipe bender. I'm in Dorset though
liam.mccaffrey
posted on 24/3/15 at 02:05 PM Reply With Quote
Yes its me, 7 years ago when I lived in Oklahoma. I'm about 3.5 stone lighter now
Build Blog
Build Photo Album
ChrisLeary
posted on 24/3/15 at 03:07 PM Reply With Quote
I don't mind paying the postage and for the tube if you have some spare.
The legs each side of the bend need to be about 250mm.
Chris.
Marcos Controls
posted on 24/3/15 at 03:17 PM Reply With Quote
What wall thickness are you looking for? Is it to be welded onto something else? or it is cosmetic? So many questions
Marc
liam.mccaffrey
posted on 24/3/15 at 04:12 PM Reply With Quote
I have some 0.75" stuff and probably enough too.
I'll let you know tonight.
Build Blog
Build Photo Album
ChrisLeary
posted on 24/3/15 at 05:26 PM Reply With Quote
wall thickness doesn't really matter as long as it's thick enough to weld. Probably 1.2mm?
Chris
Marcos Controls
posted on 25/3/15 at 04:31 PM Reply With Quote
These look ok? It's 19mm seamless pipe with 2mm wall thickness . They will need trimmed back as I've left them slightly longer than 250mm a side.
Marc
brum_gustavo
posted on 25/3/15 at 07:45 PM Reply With Quote
19 mm tubing can be bent by hand without a bender, if wall thickness is above 1.5mm. I bent a few for my locost. I made a wooden jig ( jus a piece of wood with a radiused end 50mm radius). Fixed it to a vise with the tube and bent it over the radius.
Build diary: http://gustavobrum.wordpress.com/
