Author: Subject: Starter for ST170 on an MT75
bombero
posted on 1/4/15 at 06:58 AM Reply With Quote
Helping out a mate fitting an ST170 onto an MT75 box - no issues but now find that the starter motor can't fit as it fouls up against the alloy part of the sump. Even after shaving off much of the sump excess, the starter still fouls up against the contours of the sump.
Any suggestions? Anyone use a Brise or a Wosp?
r1_pete
posted on 1/4/15 at 07:26 AM Reply With Quote
Grind more off:
starter2
starter2
That's a QX Components QS1221 starter if you need a slim one.
I didn't like the look of the ground sump, so used an all alloy one with a couple of reliefs
Phase 2 sump on phase 3
austin man
posted on 1/4/15 at 07:28 PM Reply With Quote
Had a relief cut out in my zetec sump
bombero
posted on 1/4/15 at 10:23 PM Reply With Quote
Originally posted by r1_pete
Grind more off:
starter2
starter2
Hi, can you confirm that this is a Quinton Hazell part as my local motor factors are having trouble with the part number...
bombero
posted on 1/4/15 at 10:46 PM Reply With Quote
@r1_pete, I see another one of your pics shows a QX Components Ltd label so not a QH part at all - my mistake! I'll contact them tomorrow, cheers!
