Author: Subject: Help needed 1.4 fiesta Zetec fast idle fault
bill132hotrod
posted on 12/4/15 at 08:27 PM Reply With Quote
Hi guys
My boys fiesta has developed a fault, it revs at 3000 rpm from start up and will not drop.
It started all of a sudden you start it up and it revs at 3000rpm, checked all connections i can see and get too but nothing helps. any idears please.
I read that if you disconnect the battery it will reset the computor values so trying that at the mo.
thanks in advance,
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
perksy
posted on 12/4/15 at 08:30 PM Reply With Quote
What year Fiesta ?
bill132hotrod
posted on 12/4/15 at 08:35 PM Reply With Quote
Hi there .
Its a 1.4 Zetec 54 plate. No fault codes and drives fine otherwise.
[Edited on 12/4/15 by bill132hotrod]
adithorp
posted on 12/4/15 at 08:42 PM Reply With Quote
Off the cuffl... Check the breather hose from the PCV valve to the inlet. They're known the split and suck air. Not easy to see down under the inlet manifold.
http://jpsc.org.uk/forum/
bill132hotrod
posted on 12/4/15 at 08:45 PM Reply With Quote
Already changed that recently, this is a new fault.
Madinventions
posted on 12/4/15 at 10:43 PM Reply With Quote
Could be the idle air control valve is stuck open?
There are a lot of vacuum hoses on the inlet manifold; try pulling each one off and seeing if the revs rise.
View my band website:
http://www.shadowlight.org.uk
Jenko
posted on 13/4/15 at 05:47 AM Reply With Quote
To rev, the car needs air.....check for cracks around manifold, throttle closed, throttle cable, etc, etc.
MY BLOG - http://westfieldv8.blogspot.co.uk/
