Author: Subject: Brake discs for electrolysis?
Slimy38
posted on 10/5/15 at 02:18 PM Reply With Quote
Just before I throw out an old set of brake discs, it did occur to me that they are solid iron. So can they be used for electrolysis as the sacrificial element?
Angel Acevedo
posted on 10/5/15 at 04:13 PM Reply With Quote
They may be used but I thin they would be awkward to use.
Several smaller pieces is better
IMHO...
posted on 10/5/15 at 05:07 PM Reply With Quote
Good idea batman, wire up parralel with one each side of the tub/bucket...
Thanks, I'm going to try t!
MikeR
posted on 10/5/15 at 07:02 PM Reply With Quote
Or bottom of the tub with a draining board plastic mat on top of to give a small gap to the item being cleaned perhaps?
Slimy38
posted on 10/5/15 at 07:12 PM Reply With Quote
Yep, this was my first thought, large surface area either side of the piece. I believe that while the solution does react all over, there is still a 'line of sight' aspect to the rust removal. So one either side makes sense.
And I can't imagine them wearing out as quick as rebar.
loggyboy
posted on 10/5/15 at 08:07 PM Reply With Quote
Used a brake disc for my last session. Was v good. Vented helps with surface area also.
Mistral Motorsport
Irony
posted on 10/5/15 at 09:08 PM Reply With Quote
All round the item works best. I used some iron bar and bent it in a large coil around the object.
Mark100
posted on 10/5/15 at 10:10 PM Reply With Quote
use graphite rods it cleaner works better to
posted on 11/5/15 at 10:49 AM Reply With Quote
BUT, where can you get them???
posted on 11/5/15 at 03:05 PM Reply With Quote
Readily available on eBay, though not overly cheap.
HowardB
posted on 11/5/15 at 03:12 PM Reply With Quote
didn't you used to be able to get them from breaking open the blue eveready zinc-carbon batteries? I am sure that I remember doing that,.. D cells
good luck
Howard
Slimy38
posted on 11/5/15 at 03:22 PM Reply With Quote
I can find two sources, the best option are graphite gouging electrodes but it seems difficult to get the pure carbon ones rather than the copper coated ones. And they're not cheap.
The other source is stirring sticks for smelting, although these seem to be pretty much pencils without the wood!
posted on 11/5/15 at 03:52 PM Reply With Quote
Ive just wired two brake discs together and switched it on, we'll see how it gets on
Angel Acevedo
posted on 11/5/15 at 07:44 PM Reply With Quote
Never thought of these.
Mechanical pencil leads??
