Author: Subject: Brake master cylinders
Markymark
posted on 18/5/15 at 07:37 PM Reply With Quote
Here's probably a dumb question!
I have a OBP pedal box with bias brakes and am running all the brake pipes, does it matter if the front master cylinder is on the right or left?
Most pictures show the front cylinder on the left, but I have just made the front brake pipe up to the right cylinder, if that makes sense.
Many thanks in advance
Mark
rodgling
posted on 18/5/15 at 07:54 PM Reply With Quote
No, doesn't matter. Whatever is best for routing the pipes
[Edited on 18/5/15 by rodgling]
gremlin1234
posted on 18/5/15 at 09:05 PM Reply With Quote
it matters if they are different sizes, but then you could unbolt them and swap them over
Markymark
posted on 18/5/15 at 10:42 PM Reply With Quote
Thanks Guys
Yes will make sure the right cylinder size goes to the front and to the rear, certainly make routing the pipes easier!
Thanks again
Mark
