Author: Subject: Connecting turbo plenum to bike carbs
greavesy7
posted on 18/5/15 at 08:47 PM Reply With Quote
As title says how do you do it ?
posted on 18/5/15 at 08:49 PM Reply With Quote
You need some interface that seals.. Maybe the part of the original airbox with O rings????
greavesy7
posted on 18/5/15 at 09:00 PM Reply With Quote
All the ones I have seen look sealed then attached onto the trumpets with silicon and hose clips
https://geoffmm.wordpress.com/turbo/
cliftyhanger
Maybe a silly question, but are the carbs suitable for turbo use? If not, don't they have to be inside the pressurised airbox?
greavesy7
posted on 18/5/15 at 09:14 PM Reply With Quote
Bike carbs can Handel boost very well
40inches
posted on 18/5/15 at 10:15 PM Reply With Quote
They have a hose to the float bowl to equalise the pressure.
mark chandler
posted on 18/5/15 at 11:06 PM Reply With Quote
Be warned, even quite low boost is hard to properly contain, the plenum needs to be quite strong so you will struggle just pushing air into a standard airbox.
My Ali one split where it flexed so I had to weld pins across the wide area parts to strengthen it.
greavesy7
posted on 19/5/15 at 11:43 AM Reply With Quote
I wasn't intending to use the standard air box I was more interested in how people have conected the plenum to the carbs
cliftyhanger
posted on 19/5/15 at 11:52 AM Reply With Quote
Ah, I am now educated...
furryeggs
posted on 23/5/15 at 07:51 AM Reply With Quote
Holshot racing do turbo kits for carbed fireblades and blackbirds.
