Author: Subject: Duratec Bell Housing for type 9 or 4 speed
Digimon
posted on 1/6/15 at 07:42 PM Reply With Quote
Duratec to type 9 or 4 speed Bell housing comes with the V6 Mondeo slave cylinder fitted
**LINK** retro-ford Duratec-type-9-bell-housing
**LINK** Hydraulic-clutch-release-bearing
The bell housing to gearbox mounting holes use 12mm bolts. There are 2 cracks to the edge of the starter motor cut out which will need welding, its any easy repair and make this a very cheap bell housing for someone doing a duratec conversion
You may need spacers to set the correct slave clearance/height, these are available from Retro Ford website
£150 posted within the UK mainland only
Ryegault
posted on 4/6/15 at 10:08 AM Reply With Quote
Duratec bellhousing
Hi. would you accept £130 posted?
Thankyou
Digimon
posted on 4/6/15 at 10:22 AM Reply With Quote
Thankyou
Hello,
£140 posted and you have got a deal
Regards
Simon
Digimon
posted on 8/6/15 at 04:58 PM Reply With Quote
Bump
Digimon
posted on 10/6/15 at 10:52 AM Reply With Quote
Bump
Now £140 posted.
I thought this would be snapped up by now, cheap bell housing for someone even after its repaired
Digimon
posted on 10/6/15 at 06:44 PM Reply With Quote
Now on the dreaded ebay
http://www.ebay.co.uk/itm/Retro-Ford-Duratec-Bellhousing-/281718797102?
