<<  1    2  >>
Author: Subject: Hillclimb/Sprint Fisher Fury Hayabusa.
Dopdog
posted on 11/6/15 at 03:44 PM Reply With Quote
For sale is my fisher fury, this is not your run of the mill car. It was built by westgarage engineering and has extra chassis bracing giving rigidity that enables this car to turn in like no other Sylva/Fisher/Raw I have every driven.
This is the lowered race spec chassis version giving a much lower centre of gravity with a full light weight body with carbon fibre light covers and full roll cage
Suspension and Steering
Fully independent front and rear
Lightweight alloy front hubs
Fully rose-jointed throughout with all new joints (just fitted).
Single Adjustable AVO shock absorbers front.
Double Adjustable Protech shock absorbers rear.
High ratio “quick” steering rack.
Quick release steering wheel with dash control buttons.
Digidash.
New 6 point schroth full harness.
Flatshifter Pro up and down clutchless shifting (down blipper not fitted but will be supplied).
Freelander diff casing and crown wheel & pinion
Quaife ATB differential
Brakes
Tilton pedal box & cylinders with remote fluid reservoirs
Adjustable brake bias
Front - “Hi-Spec” 4 pot aluminium callipers, 280mm discs, 1144 pads
Rear – Sierra 4x4 callipers and discs, 1144 pads
Engine
130cc Extreme Engines Suzuki Hayabusa with dry sump.
New Glpro with atre (blue)
New power commander 5 never fitted.
I have the receipt from extreme engines and it was rebuilt on 23-04-12.
Since being built it did 2 events in Scotland then I have driven it 4 times.
Stage 1 tune
full gas flow on head
regrind valves new v-stem oil seals
Kent Suzuki 24 spec cams with APE adjustable sprockets.
Ross 81mm high comp pistons
new cam chain
all new selector forks and selector shaft
new 3/4th double gear
1st gear thrust washer
Pair of undercut gears 6th and 2nd
new output shaft
Rear selector shaft
Flat billet sump
PACE twin scavenge dry sump pump
Aluminium oil tank
18 Row Oil cooler
Large bore Aeroquip pipe and fittings throughout
Remote clutch slave.
New starter clutch
Billet starter cover and idle gear.
New ITG filter.
Davis Craig electric water pump
4-2-1 Exhaust manifold custom built to fit the car and retain the correct Suzuki pipe lengths, twin box with rear exit (this passes all noise tests).
Wheels
Dry- Oz Racing Superleggera 15x7J with hillclimb slicks - used
I am sure there is more but for pictures please ask and I can email them.
£8500ovno
daniel mason
posted on 11/6/15 at 04:53 PM Reply With Quote
Now that's a steal. Pm gaz gaz he may be interested in a competition car simon!
mark chandler
posted on 11/6/15 at 07:05 PM Reply With Quote
It's a very nice car indeed, all the extra bits you want to buy for a price without.
Bargin
J-16
posted on 11/6/15 at 07:26 PM Reply With Quote
I may have missed it but is the car road legal?
Dopdog
posted on 11/6/15 at 07:29 PM Reply With Quote
No not road legal. Forgot to put that bit in
dilley
posted on 11/6/15 at 08:00 PM Reply With Quote
Is this the engine that was for sale?
gaz_gaz
posted on 11/6/15 at 08:20 PM Reply With Quote
You are a boy Dan.
If i can sell the chassis kit and my CBR motor to free up space and cash and this is still available then I'd be interested!
Dopdog
posted on 11/6/15 at 08:29 PM Reply With Quote
Yes the very one, another change of plan
Dopdog
posted on 11/6/15 at 08:33 PM Reply With Quote
a picture for you,
Dopdog
posted on 9/8/15 at 09:13 PM Reply With Quote
BUMP
I have just seen a car that I would like and am just seeing if anyone is interested in the fury. It is the same spec as above but is now on 8 x 13 superlights with slicks.
priced to sell at £8000.
Just for info this is a very quickcar and has many FTDs with me in it. Very easy to drive and ready to go.
Thanks for looking
Simon
daniel mason
posted on 9/8/15 at 09:16 PM Reply With Quote
Bloody hell simon. You need to make your mind up
I know of a £12k force but that's another story!
[Edited on 9/8/15 by daniel mason]
Dopdog
posted on 9/8/15 at 09:23 PM Reply With Quote
I know I think I am going mental and cannot believe you have tempted me with this as well.
I think my brain is on overload will see if anyone wants the fury first
daniel mason
posted on 9/8/15 at 09:25 PM Reply With Quote
There will be a further price cut for Simon boulter too!
Tempting eh!
Dopdog
posted on 9/8/15 at 09:28 PM Reply With Quote
Too tempting and you know I want it.
daniel mason
posted on 9/8/15 at 09:36 PM Reply With Quote
There's many to choose from and it's a buyers market so pick the right one!
gaz_gaz
posted on 10/8/15 at 09:45 AM Reply With Quote
such a lot of car for the money this.
had I not bought the engine and bodywork last week I think I'd have bought it. seriously lacking the motivation to put my own together and just want to go play!!
Dopdog
posted on 10/8/15 at 09:58 AM Reply With Quote
Go on Gary you know you want to
Dopdog
posted on 11/8/15 at 06:22 PM Reply With Quote
On the dreaded Bay of E
gaz_gaz
posted on 11/8/15 at 06:29 PM Reply With Quote
I can't believe this car hasn't sold.
Can you go much faster for £8000?
Dopdog
posted on 11/8/15 at 06:32 PM Reply With Quote
The answer there is no
daniel mason
posted on 11/8/15 at 06:42 PM Reply With Quote
It would have sold if you weren't driving around In an Aston Martin gaz!
Then you could have afforded to buy it!
[Edited on 11/8/15 by daniel mason]
gaz_gaz
posted on 11/8/15 at 08:08 PM Reply With Quote
Yes but I'd look a right prat doing my James Bond impersonation in a Fisher Fury :-)
If I hadn't bought the engine and bodywork last week I'd have gone for this but I'm in too far too turn back now, shame as I'd much rather be playing in cars than throwing spanners round the garage in a huff!
daniel mason
posted on 11/8/15 at 08:18 PM Reply With Quote
Just sell the bits!
The motor was a bargain so that'll pay for itself. The chassis should easily sell with bodywork
gaz_gaz
posted on 11/8/15 at 08:25 PM Reply With Quote
lol. you make it sound so simple...
daniel mason
posted on 11/8/15 at 08:29 PM Reply With Quote
That's how I do it. If I want I buy. It's an expensive way of doing business though
<<  1    2  >>
