Author: Subject: Inboard brake
sprouts-car
posted on 12/6/15 at 04:36 PM Reply With Quote
Inboard brake
Afternoon all,
What does the IVA test say regarding inboard brakes?
The only problem I can think of it you'd loose braking if a drive shaft snapped. But how often that happen?
I'm thing of a setup like this:
Build blog
Slimy38
posted on 12/6/15 at 05:03 PM Reply With Quote
I don't remember reading anything about the location of a brake disc, only that the braking system must achieve the required effort vs kerbweight, and the fronts lock up before the rear.
[Edited on 12/6/15 by Slimy38]
Matt21
posted on 12/6/15 at 05:09 PM Reply With Quote
I assume the inboard brake would only be for the rear wheels? and the fronts still have callipers/disks on the hubs?
Bluemoon
posted on 12/6/15 at 05:21 PM Reply With Quote
Some production cars are like that should be fine...
Slimy38
posted on 12/6/15 at 05:54 PM Reply With Quote
I would assume that an inboard brake would require some sort of connection to the wheel, so driveshafts are probably a good idea...
mark chandler
posted on 12/6/15 at 06:27 PM Reply With Quote
Jaguar ran inboard rear discs for 50 years, Alfa also had some cars with them as well.
The only drawback is losing heat from them.
HappyFather
posted on 12/6/15 at 07:27 PM Reply With Quote
Check this guy's photos on facebook. The earlier ones from 2013.
He has inboard brakes and the car is on the road.
I believe he is a member here, or was.
https://www.facebook.com/LotusSportster7/photos_stream
smart51
posted on 12/6/15 at 07:43 PM Reply With Quote
ISTR that the citroen DS had inboard discs at the front, and some elderly Jags. I can't think of anything modern.
gremlin1234
posted on 12/6/15 at 08:29 PM Reply With Quote
how you doing the hand brake?
jacko
posted on 12/6/15 at 08:45 PM Reply With Quote
NSU RO80 had inboard brakes at the front
jacko
posted on 12/6/15 at 08:53 PM Reply With Quote
He is indeed a member its hicost
Sam_68
posted on 12/6/15 at 08:58 PM Reply With Quote
Jaguar brakes were moved outboard in 1993, which isn't that elderly, when you're my age!
The Citroen 2CV also had inboard front brakes; as did the AlfaSud (with handbrake operating on the front). The 1970's/'80's RWD Alfas (eg. the 75, the GTV6 and up to and including the SZ in the early '90's) used a rear mounted transaxle with inboard brakes, too.
I had a Raffo Tipo 12 kit car that used the AlfaSud engine, transaxle and inboard brakes, moved to a mid-engined location, and several other kit cars used this set-up (including the Pelland/Kudos).
As said, cooling (also bear in mind heat-soak from the brakes to the diff) and access to change the pads/discs are the usual objections, but can be overcome with care and thought.
Plenty of single-seaters run the set-up suggested, particularly on hillclimb cars (though in that instance you hardly need to worry about heat issues), and indeed many get away with a single rear disc and caliper.
There's certainly nothing to stop you in the IVA regulations
[Edited on 12/6/15 by Sam_68]
smart51
posted on 12/6/15 at 09:27 PM Reply With Quote
I didn't realise that Jags had them so late. I was going to say 2CV then wasn't sure.
snapper
posted on 13/6/15 at 06:11 AM Reply With Quote
My Alfasud had inboard front discs.
The drive shaft bolts snapped, I lurched right at an alarming speed
Not an issue for IVA
Handbrake can use calipers made for that or second mechanical arrangement
I eat to survive
I drink to forget
v8kid
posted on 13/6/15 at 06:37 AM Reply With Quote
I seem to recall that inboard brakes have some strange effect on suspension movement when braking and cornering at the same time but I'm blessed if I can remember what
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Bluemoon
posted on 13/6/15 at 06:43 AM Reply With Quote
I think if there is an effect it will depend on the suspension type. It's really no diffrent to engine breaking after all (just a bit more off it!)...
Ivan
posted on 13/6/15 at 09:14 AM Reply With Quote
Most Jag based Cobra Kits have inboard brakes.
Only thing to be aware of is that if you have anti dive for outboard brakes built into your suspension then inboard brakes impact on that.
Toltec
posted on 13/6/15 at 02:02 PM Reply With Quote
The TVR wedges use a Jag setup at the rear with the inboard brakes, getting at them was a pita, however you probably will not have that problem. On track days they would get so hot that not only would the pads smoke, but the grease in the universal joints would get hot enough to start leaking out.
Make sure you duct plenty of cooling air at them or you could get problems with the diff and CV joints.
SJ
posted on 13/6/15 at 02:35 PM Reply With Quote
Sud driveshaft bolts have a habit of working loose is not loctited enough. I remember lying under my Sprint in damp gutter by Norwich cathederal doing up the shaft bolts so I could drive home!
r1_pete
posted on 13/6/15 at 03:18 PM Reply With Quote
My E Type has inboard brakes on the rear, all but the Mk2 jags had the same design back end up till about 84.
It does mean any joints in the shafts between the brake disk and the wheel hub become MOT tested.
