Author: Subject: Strange ABS Light on my tintop -I need your advice, What do you think?
novacaine
posted on 25/6/15 at 07:48 PM Reply With Quote
2001 51 reg ford focus old school TDDi 160,000 odd miles
I've got an ABS light up along with the brake warning light (same one as handbrake light) stay on all the time, not intermittent
Been like this since I bought the car
Thing is, I dont have, and never have had ABS fitted to the car, there are no sensors and no pump
(I've done driveshafts and brakes all round so should have spotted something if I have ABS)
Tried ECU reset (disconnect battery, join leads together and leave for 10 minutes)
No wiring faults with the handbrake switch or brake fluid sensor circuitry - I'm convinced it is something to do with the none-existent ABS problem
I'm really at a loss with this one - tried to get it on diagnostics but cant seem to get my cheapy Bluetooth adaptor to connect
any advice really appreciated
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
ian locostzx9rc2
posted on 25/6/15 at 08:07 PM Reply With Quote
May have a combo meter issue something feeding back through the warning lights !
posted on 25/6/15 at 09:51 PM Reply With Quote
Check a fuse hasn't been put into a random vacant slot that shouldn't be occupied on your model.
[Edited on 26/6/15 by britishtrident]
tegwin
posted on 25/6/15 at 10:13 PM Reply With Quote
Do you have a dodgy brake fluid level sensor? Possible that it thinks you have low brake fluid and is giving a fault.
www.verticalhorizonsmedia.tv
olberj
posted on 26/6/15 at 06:36 PM Reply With Quote
That'd be my first guess.
Shoild problems persist, remove the bulb.
prawnabie
posted on 27/6/15 at 08:34 AM Reply With Quote
A 51 plate focus wouldn't have the standard abs sensor and trigger wheel setup - it woul read wheel speed from the back of the wheel bearing.
They are also common for random instrument panel faults!
[Edited on 27/6/15 by prawnabie]
novacaine
posted on 28/6/15 at 02:53 PM Reply With Quote
Think I've figured it out
The instrument cluster was out of a breakers yard. I guess the cluster was set up for ABS and was looking for the ABS controller, when it couldn't find it, it fired the ABS light,
Thanks for all the replies folks!
