<<  1    2    3    4  >>
New Topic New Reply
Author: Subject: Raptor RB project
Rossmcleod
posted on 28/6/15 at 08:19 PM Reply With Quote
Raptor RB project
I'm new to the kit car forum
Hi guys
The project has started
My plans
Kit car with a skyline engine
Target weight 600 kg
Standard skyline engine puts out standard 320ishhhhh give or take
Rossmcleod
posted on 28/6/15 at 08:34 PM Reply With Quote
Skyline engine
Dopdog
posted on 28/6/15 at 08:38 PM Reply With Quote
that is one massive engine. Looking forward to more pictures and progress reports.
marco
posted on 28/6/15 at 09:04 PM Reply With Quote
250hp Standard.
Going to watch this carefully, I've owned a lot of skylines, tuned and rebuilt the engines and done a full conversion previously although not in a seven chassis.
Rosco86
posted on 28/6/15 at 09:11 PM Reply With Quote
Looks like it could be a nice build!
My Build Thread
Rossmcleod
posted on 28/6/15 at 09:36 PM Reply With Quote
Originally posted by marco
250hp Standard.
With a map and a few bits and bobs it will go to 320ishhh stage 1
[Edited on 28/6/15 by Rossmcleod]
gaz_gaz
posted on 29/6/15 at 04:14 PM Reply With Quote
I done a RB25 swap into an S13 about 10 years ago and weighed the motor and box before fitting. From memory the dressed engine and box weighed in over 300kg. 600kg maybe a little optimistic.
Rossmcleod
posted on 29/6/15 at 05:04 PM Reply With Quote
It's very optimistic mate the engine weights about 300 and the gearbox is 45kg ha ha
it's very optimistic a lot of stuff can be taken off because a don't need it like aircon and stuff
wylliezx9r
posted on 29/6/15 at 05:33 PM Reply With Quote
With that much torque I don't see weight being a problem.
George Best
scudderfish
posted on 29/6/15 at 05:37 PM Reply With Quote
OK, I'll be the first.....
Can I have a go when it's done?
Rossmcleod
posted on 29/6/15 at 06:44 PM Reply With Quote
Ya no prob lol
It's going to be lively wee beasty ha ha
Rossmcleod
posted on 13/7/15 at 05:26 PM Reply With Quote
Over night parts from Japan
Target : 540 BHP per ton :-)
Doctor Derek Doctors
posted on 13/7/15 at 07:32 PM Reply With Quote
But hector and his crew are going to be running Civics with Spoon engines....
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Rossmcleod
posted on 13/7/15 at 09:09 PM Reply With Quote
Good for them
I'm going to leave there arse on the starting line ha ha
Rossmcleod
posted on 17/7/15 at 09:41 PM Reply With Quote
It's crazy the difference from new to old
Rossmcleod
posted on 25/7/15 at 11:04 PM Reply With Quote
Little update
Getting the roll cage welded together
Rossmcleod
posted on 2/8/15 at 09:10 AM Reply With Quote
Wee update
Frame is finished going to powder coat next week
Rossmcleod
posted on 5/8/15 at 08:03 PM Reply With Quote
Not much has happened waiting on the frane coming back from the powder coater.
On the plus side new 1.5mm head gasket has arrived
Rossmcleod
posted on 19/8/15 at 05:45 PM Reply With Quote
Frames back from the powder coater
Next job is fit engine do wiring
After wiring finished I get to pick it up and the project is all mine
[Edited on 19/8/15 by Rossmcleod]
Rosco86
posted on 19/8/15 at 06:48 PM Reply With Quote
Looking good, did you have the chassis blasted before powder?
My Build Thread
Rossmcleod
posted on 19/8/15 at 07:29 PM Reply With Quote
Sand blasted mate
Rossmcleod
posted on 27/8/15 at 07:42 PM Reply With Quote
Front inlet plenum arrived this morning
The front inlet plenum usually exits in the middle so this one has been modified
[Edited on 28/8/15 by Rossmcleod]
Rossmcleod
posted on 27/8/15 at 07:45 PM Reply With Quote
So a brought a r34 standard intercooler vs r33 standard intercooler
Here's a pic comparing the 2
The r34 is a wee bit bigger and a wee bit thicker
A also sandblasted it to give it a clean and then blasted it with air :grinno:
Then hung up to paint
Painted with primer then 1st coat of black
CosKev3
posted on 28/8/15 at 07:59 AM Reply With Quote
Jesus it will be a handful! :O
Rossmcleod
posted on 23/9/15 at 09:40 PM Reply With Quote
Little update
Fitted the base to the frame
Also test fitted the engine make sure it fits
[Edited on 23/9/15 by Rossmcleod]
<<  1    2    3    4  >>
New Topic New Reply
