Author: Subject: K20a into E30? which gearbox ?
steveydee
posted on 1/7/15 at 10:17 PM Reply With Quote
I love my type r but its a bit of a dog and I love the engine and have been thinking of putting it into a rwd body but want it to be a daily and practical so ive just bought a bmw 316i e30 (1990)
Has anyone known of anyone to use a bmw box on the k20a?
And the mt75.... are the 5 and 6 speed boxes interchangeable? As id like to go for 6 speed if its the same amount of work
I know the rx8 gearbox has been done but can't find any details on it
Thanks in advance for your help
I now its not a kitcar but this is the only helpful forum I know of, bmw people would just shout abuse and tell me to fit a big heavy 6 cylinder bm lump in that makes less power than the k20
Brook_lands
posted on 2/7/15 at 08:51 AM Reply With Quote
I'm afraid this is the teacher in me coming out.
I would suggest that for these sorts of projects the following applies
Outcome = Money x (Enthusiasm + (Skill x Time x Facilities)).
As it is not a standard kind of swap it is going to be tough going and unless you have a lot of time, facilities and skill then the kind of money it would cost would be disproportionate to the outcome unless you just want to do it and have plenty of dosh.
RWD boxes, especially 6 speed are not common. The chances of one bolting straight up to the Honda engine is remote, we tend to be spoilt with Ford.
Honda S2000 comes to mind but you would have to do your research as to whether it fits.
There is so much to plan and think about before you start spending your cash.
I'm afraid I've seen too many people start from the wrong place with projects usually based on saving or using a car they already own rather than starting with the outcome they want and working back to find the best way of getting there. Although its a nice idea I expect getting the engine to bolt to a RWD gearbox will be one of the simpler problems to solve.
posted on 2/7/15 at 10:20 AM Reply With Quote
It doesn't, only two of the bolt holes line up unfortunately so you'd still need to make an adapter plate.
wylliezx9r
posted on 2/7/15 at 11:23 AM Reply With Quote
I would be looking at something like a nissan 200 sx for this conversion. Drop everything in in one go and pretty straightforward electrics.
The k swap could be done but will be complex and expensive , you'll be looking at about a grand just for an ecu - you could probably get a whole 200sx for that.
George Best
Ugg10
posted on 2/7/15 at 11:27 AM Reply With Quote
Things to work out -
1) Do the bolts between the bellhousing and the engine fit (previous post suggest not) > therefore adaptor plate needed
2) Does the K20 have a spigot bearing cavity in the end of the crank, some FWD only engines do not
3) If yes to 2) then is this compatible with the diameter of the input shaft of the gearbox
4) So, of you can design/make and adaptor plate and the spigot bearing/input shaft problem is solvable then next on the list is starter motor position, hopefully solvable with the adaptor plate if engine side, if gearbox side then may need either gearbox mods to get it to mesh with the flywheel
5) If everything is still going OK, then we are now at the stage of looking at gearbox input shaft diameter and spline design and whether you can get a clutch plate and cover to match this and the flywheel.
so- as others have said, the F20 is basically a similar engine and comes already bolted to a RWD gearbox and it may be easier to bolt this in making minor tunnel metalwork mods and a new mount than trying to get a box to fit. But be aware that the BMW tend to have a different philosophy for geabox ratios and diff ratio than the Japanese card. BMW have high geared boxes and low gear diffs where as the Japanese are the other way round. Example -
BMW 328i E36 Sedan Manual
1st - 4.2
2nd - 2.49
3rd - 1.66
4th - 1.24
5th - 1.00
Diff 2.93
redline - 6500
S2000 Ap1
Gear Reduction - 1.160 (hopefully I have calculated the equivalent ratio correctly below)
1st gear - 3.133 = 3.63 equiv
2nd gear - 2.045 = 2.37 equiv
3rd gear - 1.481 = 1.72 equiv
4th gear - 1.161 = 1.34 equiv
5th gear - 0.970 = 1.12 equiv
6th gear - 0.810 = 0.939 equiv
Diff - 4.10
redline - 9000
Finally, may be worth checking that the BMW boxes can rev to 9k safely/reliably, this may be the limiting factor as they may well have only been designed for 6.5k.
Hope this helps
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Dingz
posted on 2/7/15 at 12:57 PM Reply With Quote
Doesn't the engine rotate the 'wrong' way too?
went on and on.
wylliezx9r
posted on 2/7/15 at 01:57 PM Reply With Quote
No. That was the old B series engines.
George Best
Daf
posted on 2/7/15 at 01:59 PM Reply With Quote
If you want a fast E30 its certainly worth looking at BMW engine options. I appreciate you like the characteristics of the k20, but t fitted an M52 2.8 engine to mine and it was an animal. If you want really fast the s52 (m3 engine from an e36) makes an epic car - I would imagine the cost of all the complexities in fitting the k20 would be more.
That said I love it when people do things out of the ordinary, so good luck if you do the k20 conversion, it'd make a fantastic car.
steveydee
posted on 3/7/15 at 09:17 PM Reply With Quote
Thanks for your help guys. A lot more positive than I was expecting.
Ive found this and sounds like its getting common Its k20 to an AZ6 (RX8 GEARBOX)
http://www.racingforum.pl/index.php?showtopic=105452
I just need to look using a laptop to translate and see if I can contact this guy
The e30 is a cool little new home for my k20. Im not looking for an engine for the e30 if you get what I mean?
The k20 is a light little 4 pot so should be able to handle well and still have the possibility of a supercharger
As for ECU etc ive got the whole civic so I will just use the original
Ugg10
posted on 3/7/15 at 09:30 PM Reply With Quote
If you are looking at the az6 route it would be worth chatting to p9cyo on turbosports as he is selling lots of adaptor plates for this box. He now has an eBay shop.
http://www.turbosport.co.uk/showthread.php?t=500016
Type 9 Conversion Plate RX8 Kitcar Redtop Cosworth Zetec Mk 1 Mk2 Escort Capri
Nice box and will take the power and revs (also used in lexus is200, brz/gt86, 200sx and mk3 mx5) but they all have different input shaft diameters and splines but if someone has sorted the clutch and spigot bearing then that helps.
First gear is pretty short but after that it is basically a four speed rocket box with a cruise sixth gear. You xan always start off in second :--)
You can use this to check first gear speeds, 70mph revs and rev drop between gears. Note I don't think the tyre diameter bit is working so I use www.willtheyfit.com and divide by 25.4 (mm per inch).
http://www.subarugears.com/Ratios/Ratios.html
[Edited on 3/7/15 by Ugg10]
Volvorsport
posted on 3/7/15 at 09:36 PM Reply With Quote
There is a bellhousing available that mates it to a ford gearbox. Available from des Moore Rallying in northern Ireland....
[Edited on 3/7/15 by Volvorsport]
www.dbsmotorsport.co.uk
getting dirty under a bus
Volvorsport
posted on 3/7/15 at 09:42 PM Reply With Quote
Scratch that I didn't read the post properly. I thought k20a was s2000 anyway...!!
ettore bugatti
posted on 3/7/15 at 10:12 PM Reply With Quote
There has recently a swap kit introduced to get a K20A into a NB/NC Mx-5/ Miata using the Mazdas gearbox, maybe worth a look?
steveydee
posted on 5/7/15 at 12:04 AM Reply With Quote
The mx5 box is the same pretty much so yeah im trying to find what I can in them all
I know the s2000 box dont mate up but I know it has been done so that is another option
S2000 manifolds and sump to k20, do they fit?
Started to pull the civic apart today and have good look around the e30 today
steveydee
posted on 5/7/15 at 09:27 PM Reply With Quote
Just bought a box from an s2000
