Author: Subject: Whats my top joint and Taper
Dopdog
posted on 2/7/15 at 04:57 PM Reply With Quote
Hi Guys,
Hopefully you can help me with this one. can you tell me what my top joint is and then can anyone tell me the taper of it and if I can get a drill bit to drill one?
posted on 2/7/15 at 05:09 PM Reply With Quote
Looks like an Austin Metro one.
adithorp
posted on 2/7/15 at 05:23 PM Reply With Quote
Yes, Fury with Escort (or Sierra) uprights uses Metro ball joints.
Beware very early Metros used 2 different joints top/bottom and they're different taper sizes. The ones on the Fury are the same as the slightly later ones that were both the same... KitCarWorkshop even sent the wrong ones with my kit.
http://jpsc.org.uk/forum/
Dopdog
posted on 2/7/15 at 05:48 PM Reply With Quote
Thanks for the replies, my old wishbone has a larger taper and the new one I have is smaller, any clues as to the year or version I need?
adithorp
posted on 2/7/15 at 06:55 PM Reply With Quote
I think the larger one is the one used on one end of the early and both ends of the slightly later Metro... My memory is a bit hazy though.
I might still have the "wrong" ones from my build somewhere.
[Edited on 2/7/15 by adithorp]
adithorp
posted on 3/7/15 at 08:17 AM Reply With Quote
Found my "wrong ones". They're quiton hazel qsj1059s
Look about 13mm small end of taper and 15mm at the other. Sorry that's vague but my digital called battery has died.
Free to a good home....
richardm6994
posted on 3/7/15 at 09:13 AM Reply With Quote
It looks like its a 7-degree tapered ball joint but hard to tell for certain from the photo.
You can buy ball joint reamers.....but they all tend to be from USA and around $80.......I had one but lent it out and it got broke......I've not yet got round to replacing it as haven't needed one since.
Dopdog
posted on 3/7/15 at 08:47 PM Reply With Quote
Hi Adi, just seen this and yes please I will have them.
adithorp
posted on 3/7/15 at 10:51 PM Reply With Quote
u2u me the address and I'll send them Monday.
