Author: Subject: a thin carpet
killerferret666
posted on 9/7/15 at 08:16 AM Reply With Quote
a thin carpet
As the title says I'm looking to get a thin carpet. Not felt (sub box style).
Has anyone bought and used some examples. I'm after some real life experiences really.
[Edited on 9/7/15 by killerferret666]
Building DDR GT4
Miami Gt4 Blog - Click Here
Slimy38
posted on 9/7/15 at 09:20 AM Reply With Quote
I got some cheap carpet from one of the roll end places, but as soon as it got wet the backing separated from the top. It left sticky white goo everywhere, and no usable carpet. Actually, that might be the felt type stuff you're referring to.
If I do go down the carpet route, I'll be getting some proper waterproof stuff. It's only going to be a square metre or two so won't be breaking the bank.
trextr7monkey
posted on 9/7/15 at 09:26 AM Reply With Quote
I bought a roll of thin grey Carpet from a bloke in the cowshed at Stoneleigh. It looks much better than the thick woolly black stuff and was described as being the stuff used by Volvo and is moisture resistant and looks as if it would fit into tight corners easily.
We sold the car that it was intended for so have never tested it out. I planned to use a heel mat or plate to stop wear by the pedals
killerferret666
posted on 9/7/15 at 09:29 AM Reply With Quote
thanks guys getting wet wont be an issue as its in a cabin in this case.
Building DDR GT4
Slimy38
posted on 9/7/15 at 10:21 AM Reply With Quote
Bear in mind that my 'wet' was only wet footwear rather than being outside in the rain, it still managed to soak through and delaminate the carpet. Unless you're definitely going to be getting in with bone dry shoes every time you should at least consider some water resistance (if only to avoid the 'wet dog' smell!).
40inches
posted on 9/7/15 at 10:44 AM Reply With Quote
I used this from CBS.
Still looks good after 3000miles, even under the drivers heels.
After checking they only have it in 2X1metre rolls at the moment.
killerferret666
posted on 9/7/15 at 11:09 AM Reply With Quote
Do you have any photos of it installed?
Building DDR GT4
steve m
posted on 9/7/15 at 11:22 AM Reply With Quote
I also bought carpet from one of the cowsheds at stoneliegh, about 10 years ago, and its still in my car now,
its looks fine to me
photos in my archive
steve
40inches
posted on 9/7/15 at 11:34 AM Reply With Quote
It had done 2000miles at this point, also had enough left to do the boot. It looks better in the flesh .
