Author: Subject: Fuel hose only rated to 80 celsuis
rcx718
posted on 10/7/15 at 01:56 PM Reply With Quote
I'm about to run plastic fuel hose, it's DIN 73378 certified for automotive fuel use. It's pressure rated to 100bar so assume that's enough for a multipoint EFI system. But the working temperature rating is only 80 Celsius.
Can I run this all the way to my engine or will it be over 80 C in the engine bay, on the opposite side away from the exhaust.
mark chandler
posted on 11/7/15 at 06:57 AM Reply With Quote
A hot engine will exceed 105 degree's, I would terminate on your bulkhead and extend out with flexible fuel hose.
