Author: Subject: Ford Type9 spacer drawing
TurboWood
posted on 15/7/15 at 05:26 AM Reply With Quote
Hi Gents,
I'm working on a 7 and need a spacer for my transmission. I've searched and know there are a few options out there, but the easiest part (requires less custom work) is the 30mm spacer from caterham. Unfortunately I cannot find any anywhere.
Does anyone have a drawing or the critical dimensions that I could make drawing from? This is for the Ford type 9 transmission. I would happily buy a used one if anyone has one sitting around.
Thanks,
Daniel
posted on 15/7/15 at 07:00 AM Reply With Quote
Retro ford RWDmotorsport or use the search facility on here
Paul Turner
posted on 15/7/15 at 07:56 AM Reply With Quote
From memory off the shelf the RWD one is thinner but they will make one to the full 30mm if you ask.
Have you tried a wanted in the Caterham forum?
TurboWood
posted on 15/7/15 at 01:50 PM Reply With Quote
Thanks for the help guys. I've sent some notes based on your suggestion.
Daniel
owelly
posted on 16/7/15 at 01:31 PM Reply With Quote
I took these measurements when I made my spacer. I accept no responsibility if they are all wrong but it seemed to work for my purpose!!
Type9 flange dims
Type9 flange dims
http://www.ppcmag.co.uk
Benzo
posted on 2/12/19 at 11:27 AM Reply With Quote
Type9 flange dims
Type9 flange dims
Would anyone have same information as this in Higher resolution?
When I View or print I cannot read the dimensions.
theduck
posted on 2/12/19 at 11:36 AM Reply With Quote
I tried that one some of the caterham groups, got banned almost instantly for not owning a caterham
