Author: Subject: Injection system plumbing sanity check
ianm67
posted on 20/7/15 at 03:22 PM Reply With Quote
Hello chaps,
I am going to run a 'dead end' injection set up in my car based around a set of GSXR1000 throttle bodies. The diagram below is how I think it should all fit together and would appreciate it being sanity checked by the Locost massive.....
My next question is based around the FPR...... I want to use one with a fixed rate, the question is should it be 3 bar or 3.5 bar....?
Always biting off more than I can chew.....
mark chandler
posted on 20/7/15 at 05:37 PM Reply With Quote
If you are using a bespoke ECU it will not matter, what are the injectors specified for?
If they can just meet the engines flow requirements at 3bar stick in a 3.5bar unit.
40inches
posted on 20/7/15 at 06:12 PM Reply With Quote
I've done almost the same, except I have fitted the FPR at the "T" piece point on your drawing.
ianm67
posted on 20/7/15 at 07:53 PM Reply With Quote
Hello Mark,
I am going to be running a Microsquirt. The injector specs are:
Flow Rate (45psi/100%): 230cc/min
I think that 45psi equates to about 3.1 bar so I guess I'll need a 3.5bar FPR?
daviep
posted on 20/7/15 at 08:14 PM Reply With Quote
I'm confused, he has fitted the FPR at the "T" !
How is yours different?
Davie
40inches
posted on 20/7/15 at 08:35 PM Reply With Quote
Davie
Unless I am seeing it wrong, he has a "T" piece, then the FPR In the return line from the "T" to the swirl pot. I have simply
used the FPR as the "T" piece, that eliminates a couple of connections. I think
Dusty
posted on 20/7/15 at 08:37 PM Reply With Quote
I would delete the pre injection pump filter. Fuel in the swirlpot has already been through the pre LP pump filter and HP pumps generally can't suck for toffee.
Add an injection micro filter after the injection pump. Fuel through the injectors must be super-clean.
daviep
posted on 20/7/15 at 08:42 PM Reply With Quote
Davie
OK but functionally it's the same then.
40inches
posted on 20/7/15 at 08:45 PM Reply With Quote
Davie
Yep! Just neater and less leakage points, in my opinion of course
ianm67
posted on 20/7/15 at 09:21 PM Reply With Quote
Interesting, you must have a FPR with two outlets then? Which one are you using as it would be a little neater....
Toltec
posted on 20/7/15 at 11:21 PM Reply With Quote
Hello Mark,
How much power are you expecting the engine to deliver?
jeffw
posted on 21/7/15 at 05:03 AM Reply With Quote
http://atspeedracing.co.uk/products/index.php?main_page=product_info&cPath=8_9&products_id=364&zenid=a44ba7119f7e1ff830c358e9dc19ba87 />
[Edited on 21/7/15 by jeffw]
ianm67
posted on 21/7/15 at 05:14 AM Reply With Quote
Hello Mark,
I'm more interested in torque than headline BHP to be honest, the engine is a standard 2.0 Blacktop with a gas flowed head. 170ish BHP would be nice.....
[Edited on 21/7/15 by ianm67]
ianm67
posted on 21/7/15 at 05:18 AM Reply With Quote
Thanks Jeff,
That's the one that I have been looking at. Not cheap are they? Works out at almost £100 once delivery and VAT has been added........
IanM
jeffw
posted on 21/7/15 at 07:34 AM Reply With Quote
Well....you can buy a Chinese knock-off and risk your engine or....do it once, do it right. Pays your money and takes your chances.
ianm67
posted on 21/7/15 at 08:14 AM Reply With Quote
Wise words.......
adithorp
posted on 21/7/15 at 08:20 AM Reply With Quote
You def' need a HP micro filter after the HP pump. I'd leave the HP pre-filter in until its been running a while to catch anything in the swirl tank from construction, then remove later.
Ask Jeff how he knows about cheap knock offs...
[Edited on 21/7/15 by adithorp]
http://jpsc.org.uk/forum/
Toltec
posted on 21/7/15 at 08:38 AM Reply With Quote
I think you will be pretty close to the limit of 230cc injectors at that power, going for the 3.5bar fpr to get a bit more flow would probably be better.
ianm67
posted on 23/7/15 at 04:04 PM Reply With Quote
A set of these should sort out any duty cycle / flow constraints:
eBay Item
ianm67
posted on 29/7/15 at 10:55 AM Reply With Quote
Finally found myself a fixed rate FPR at a reasonable price. £65 inc VAT and delivery..... Nice bit of engineering too.....
CorseChris
posted on 3/8/15 at 11:58 AM Reply With Quote
Re the injectors and flow, we have some GSXR 600 ITBs on the silvertop Zetec, stock motor, 3 BAR fuel pressure, 220cc/min @ 3 BAR injectors. Engine makes just a gnats short of 170bhp, duty cycle isn't outrageous. I'd expect a blacktop to make a bit more, so your 10% bigger injectors and 3.5 BAR should be pretty much bang on.
[Edited on 3/8/15 by CorseChris]
