Author: Subject: Clutch pedal setup
JeffJeffers
posted on 20/7/15 at 09:49 PM Reply With Quote
Clutch pedal setup
This is probably a very silly question but I seem to be struggling to understand levers.
I have floor mounted pedals.
I understand the the closer I attach the master cylinder to the pivot the lighter the pedal will be.
The part I'm struggling with is if I move the master cylinder mount point away from the pivot does it make the clutch more of less sensitive?
adithorp
posted on 20/7/15 at 09:59 PM Reply With Quote
It'll make it more sensitive/sharper.
http://jpsc.org.uk/forum/
scott h
posted on 20/7/15 at 11:24 PM Reply With Quote
As you move the master cylinder rod attachment away from the pedal pivot and closer to the foot pad there will be less movement of your foot for a given movement of the clutch. So it will be faster for quick gear changes but more difficult to slip the clutch in stop start traffic.
