Author: Subject: FS: Car Dolly, Lights & Alloys
killerferret666
posted on 28/7/15 at 05:28 PM Reply With Quote
All items are in Poole Dorset.
I built this car Dolly to help me with the build so its a good height and allowed me to work under the car when needed without wedging myself under there. It took about 400kg on it with my chassis + suspension, brakes etc.... I always used it with a couple of wheels under it just in case.
The middle two bars slide back and forth so can be placed well on a car and I placed lagging over it to protect chassis. The picture is from a while back a rattle can spray to tidy it up a little would do no harm. It also had some triangulation bracing added. Will fit into a car as it can be put into bits.
I also put caster wheels on it so I could move the car about. Selling it cheap just so its gone as the materials were way more. I can send more photos if required.
£60 collection only
90mm Hella Lights (LHD) Brand new
These are what they say, I obviously wanted RHD so took these out. These saw no miles nor a light wired up and are in like new condition. They will only require the little plastic clips the balls push into for mounting. The models of the lights are;
Main Beam
Part # - 1K0 008 191-05
Low beam
Part # 1bl 008 193-02
£100 for the lot, as you will need to get the plastic clips and dependant on fitting maybe make metal plate for them to fit on to.
19" alloy wheels
No idea on make the tyres are Falken 452 215/35/R19
PCB is 114 x 5 (toyota, lexus etc...)
7J ET40
Couple of the tyres should be replaced as have some splitting and slow punctures anyway. although all 4 tyres have good tread. Again very cheap to get them out of the way
£100
Building DDR GT4
Miami Gt4 Blog - Click Here
killerferret666
posted on 28/7/15 at 07:54 PM Reply With Quote
Alloys sold and collected
Building DDR GT4
