Author: Subject: Pre IVA Photos
Irony
posted on 6/8/15 at 09:05 PM Reply With Quote
Pre IVA Photos
Surely this is the biggest milestone in a build before the IVA. All comments welcome. My IVA is on Monday. Can anyone spot any mistakes..........?
Irony
posted on 6/8/15 at 09:14 PM Reply With Quote
zx12r dug
posted on 6/8/15 at 09:18 PM Reply With Quote
Hi nice build.Depending on how fussy the tester wants to be maybe the edges of the hinges on your glove box.
good luck with your test..
austin man
posted on 6/8/15 at 09:20 PM Reply With Quote
battery's not connected lol
gremlin1234
posted on 6/8/15 at 09:23 PM Reply With Quote
nice car,
agree the glove box hinges likely fail,
also too much info on the 'manufacturers plate'
(you can have that much info, but the prescribed info must be in a box of it's own.)
check the gear knob for sharp edges too
edit, shouldn't the fuel cap be tethered?
edit2: are there any side repeaters for the indicators?
[Edited on 6/8/15 by gremlin1234]
zx12r dug
posted on 6/8/15 at 09:31 PM Reply With Quote
Edges of the front hubs where the track rod bolts on.My first build was pulled up on that was easy fix just ran the grinder to take the edge off and repaint
adithorp
posted on 6/8/15 at 09:37 PM Reply With Quote
Looking good. Radii on glove box hinges and the manufacturer late were all I could see plus, I guess you've checked the front brake flexis don't foul on anything on either lock.
http://jpsc.org.uk/forum/
luke2152
posted on 6/8/15 at 09:39 PM Reply With Quote
front wing brackets look a bit sharp maybe?
Are the front indicators the specified distance from the centre?
Both look borderline might be ok
The Black Flash
posted on 6/8/15 at 10:02 PM Reply With Quote
Looks a really good quality build. Nothing particularly jumping out apart from things mentioned above. I assume you've checked all of the light position and angles of visibility. Good luck
Pojo
posted on 7/8/15 at 07:29 AM Reply With Quote
Looks real good Irony. Glad to see another Viento nearly on the road. good luck and look forward to seeing it in the flesh
Irony
posted on 7/8/15 at 07:40 AM Reply With Quote
Thanks for the replies and the kind comments
Some more images
The glove box hinges were very sharp when I bought them but I dremmelled them with my Lidl Special Dremmelalike. Here are some close up pics
Fuel Filler is tethered but the key won't come out anyway. I just belt and braces it
Manufacturers Plate is based on the IVA guide to passing the IVA
Can be found here for anyone whose interested
linky
My Plate
IVA Approved Plate
Close up of front wing stay, again I rounded it off but maybe not enough
After looking around the car I found this boot catch which I think might not pass.
Let me know what the collective thinks of the above!!!
Thanks again.
Irony
posted on 7/8/15 at 07:43 AM Reply With Quote
Oh and I am a bit concerned about these
SteveWallace
posted on 7/8/15 at 10:38 AM Reply With Quote
That looks like a really nice build that will give confidence to the tester that its a job well done. A few observations from me.
You've used the same wing mirrors as me and they look to be about in the same place, so you should be OK with rear visibility
You exhaust appears to sit quite far out from the side of the car, so just make sure that the bolts on any clamps are turned so that they cannot be touched by the radius ball
You might want to trim the edges of the upper seat belt mounts just to be sure
Check that the upper ball joints on the front wishbones cannot be touched by the radius ball or that they are in the exempt zone. I think that someone on here failed because the edge of the casing was too sharp.
I was concerned about the front wing stays being too tight a radius at the edges, so I put two layers of wiring shrink wrap over them. Probably over kill though as it was marginal even without the shrink wrap
You could move the left hand pair of lock nuts on the brake bias bar in a turn or two as it looks as though the current position might allow too much adjustment by hand
did you remember to put a lock nut/grub screw into the front hub mushrooms?
I'm being ultra picky with the above list and they are mostly things that you could do on the day if the tester picks you up on anything. As you saw when we went with mine, they are usually happy to take tea breaks whilst you fettle.
Good luck
[Edited on 7/8/15 by SteveWallace]
Irony
posted on 7/8/15 at 11:01 AM Reply With Quote
Thanks for the reply Steve. I appreciate the time you spent looking through the images.
Mushrooms: I did put small bolts on the mushrooms as a secondary fixing.
Bias Bar: I have twiddled with the Bias Bar so that the fronts lock, try as I might I couldn't get the rears to lock. Might have something to do with the fact they are 275 wide and it was a hot day. I am hoping they will let me adjust them on the day.
Upper Ball Joint and Wing Stays: I might have another go at rounding them off a bit more. I bought a Black & Decker Power File for £4 from a car boot. I would totally reccomend one for car builders - - very very handy.
Seat Belt Mounts: I have some spare trim
Exhaust: I have just bought two decibel killers from Forure. They need a bit of fettling so I'll be fitting them at the weekend. It's not quite a case of shoving them up the pipe. They need bending slightly.
Davegtst
posted on 7/8/15 at 11:28 AM Reply With Quote
I'd get some conduit around the battery power lead.
Adam
posted on 7/8/15 at 01:29 PM Reply With Quote
Hi mate,
As every one has put above, also nut covers on the track rod ends and make sure your head lights are at the right height, 500mm as if i remember right. Only advice i would give is just to trim as much as you can and take some with you.
Looks like a great build and all the best for your test.
Adam
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 7/8/15 at 02:22 PM Reply With Quote
Missing a bonnet?
The things i noticed others have already mentioned. Good luck.
tones61
posted on 7/8/15 at 06:02 PM Reply With Quote
nice motor and build that dude,
do you need heatshields on exhaust silencers?,
Dave Bailey
posted on 7/8/15 at 06:07 PM Reply With Quote
Just an observation on the pedal box. I have the same setup but added some large washers either side of the tube with the bearing in. I was concerned that without these there was an edge that could foul and prevent travel which would not be good on the brake pedal... My tester also wanted to see the bias bar lock wired to prevent adjustment.
Dave B
Irony
posted on 8/8/15 at 12:43 PM Reply With Quote
Is this a requitement or just good practice?
The Black Flash
posted on 10/8/15 at 09:04 PM Reply With Quote
Nope!
Neilwilson
posted on 10/8/15 at 09:09 PM Reply With Quote
Great looking build...hopefully you passed today?
