Slimy38
posted on 9/8/15 at 11:17 AM |
Inertia belt orientation
Do standard diagonal belts have to go from outside top to inside bottom? IE from the drivers right shoulder to left hip? Or can they be done the other
way round? I want to reuse my donor's inertia belts but I have more room in the middle behind the occupants, rather than the outside which is
all roll bar and suspension.
posted on 9/8/15 at 11:18 AM |
Westfields have them the way you describe - or used to, anyway.
Bluemoon
posted on 9/8/15 at 11:28 AM |
Morgans use this config. Not sure if the inertia reels are different..
stevem427
posted on 9/8/15 at 03:07 PM |
My Cobra has them the other way round. Over left shoulder and fastening on the right near the door. Just standard belts.
emlyno
posted on 9/8/15 at 08:53 PM |
My Gemini has them reversed, no room in the conventional position for the inertia unit. You shouldn't have any problems with IVA.
Slimy38
posted on 9/8/15 at 09:08 PM |
Did you build in any reinforcement for the belts? I believe the Gemini has a very similar cockpit rear panel to my car, I was wondering if the single
top chassis rail is sufficient.
emlyno
posted on 10/8/15 at 10:01 AM |
I drilled and sleeved a chassis rail in the boot and took the belt over the top tube. I can't find pics at the moment but I could photo the
setup and email them to you If you want.
Slimy38
posted on 10/8/15 at 10:28 AM |
Aha, that makes sense. That gives access to some much more substantial rails, and my belts already have a 'slider' that I can fix to the
top tube. A pic or two would be really appreciated, I'll ping you my address on PM, thanks.
coyoteboy
posted on 10/8/15 at 02:52 PM |
I'd bet my bottom dollar that they're directional, looking at the mechanisms used in a few different ones. So providing you keep the same
face facing forward you should be OK. Otherwise you'll only find out they're not when you bite the steering wheel.
[Edited on 10/8/15 by coyoteboy]
Slimy38
posted on 10/8/15 at 03:34 PM |
They are yes, there's a 'weight' or something that only engages in certain directions. I found out by thinking they were broken, not
realising I was holding them crooked! They have to be perfectly upright for the belt to move.
