Author: Subject: Rainbow Dial
Jeano
posted on 13/8/15 at 02:32 PM Reply With Quote
Rainbow Dial
Anyone know what the below is?
Its attached to what looks like a sensor prope which is tied onto the water pipe to the radiator
[Edited on 13/8/15 by Jeano]
Drives: MK Indy F20c with hairdryer
cliftyhanger
posted on 13/8/15 at 02:43 PM Reply With Quote
Obvious guess is an adjustable fan switch......
ianm67
posted on 13/8/15 at 02:58 PM Reply With Quote
^^^^^ This.... ^^^^^
Always biting off more than I can chew.....
posted on 13/8/15 at 03:00 PM Reply With Quote
Rainbow is a Korean thermostatic switch manufacturer
See this link
You want to have it set to cut in about at least 8 to 9 degrees above the thermostat temperature and cut out at least 4 degrees above or the fan will run continuously.
Jeano
posted on 13/8/15 at 03:45 PM Reply With Quote
Cheers all, that makes sense tbh. Temperature runs perfectly and it has a nice overrun on the fan when i turn it off so im just going to leave it as it is
adithorp
posted on 13/8/15 at 03:56 PM Reply With Quote
If thats temp in centigrade that it comes on at (and is accurate) it must be running nearly all the time. You might want to turn it up. The fan shouldn't need to be on unless you're stationary/in traffic, as long as the cooling system is adequate. If I leave mine running by mistake (got a manual override) when moving the temp actually goes higher (assume the fan is disturbing the air flow). I'd turn it up and see how the temp copes when driving, then adjust it so it comes on as they rise when stationary. Fans normally come on around +90c.
Or it could be the sensor for your gayness gauge
[Edited on 13/8/15 by adithorp]
http://jpsc.org.uk/forum/
snapper
posted on 13/8/15 at 07:51 PM Reply With Quote
You now know what it does
If it ain't broke etc,
I eat to survive
I drink to forget
posted on 13/8/15 at 08:39 PM Reply With Quote
Really bad idea to have it set at too low a temperature..
The fan running on after the engine is stopped has no value except for cars with turbo chargers or air-conditioning.
The lower engine coolant temperature range is determine by the thermostat, if thermostat is closed the fan running is cooling the radiator not the engine. Modern engines (anything built since 1965) run the coolant in 88 to 105c range the oil should run within 10 degrees of the oil temperature.
dilley
posted on 13/8/15 at 09:43 PM Reply With Quote
Agree 100%, someone once argued with me over the boiling temp of water/coolant.... I won!!! It's not 100 degrees when it's packed like sardines....
