<<  1    2  >>
Author: Subject: Wrong Type 9
lsdweb
posted on 17/8/15 at 08:30 AM Reply With Quote
Wrong Type 9
Hi All
I have the wrong type Type 9 gearbox for my Striker - I need the longer input shaft version to work with my Caterham bellhousing and K series. I was planning on using the Type 9 as is but that doesn't now seem to be an option.
I'm trying to make up my mind on what to do! Any thoughts on the following options -
1. Swap the input shafts (I have no idea if this is possible and the last time I delved into a gearbox it wasn't a pleasant experience!).
2. Find a second hand long input shaft box (Capri , XR4?)
3. Buy an uprated box with longer shaft (an uprated box was part of a longer term plan).
4. Sell the Dave Andrews built short stroke 1400 K series and go BEC :-)
Any views appreciated!
Ta
Wyn
liam.mccaffrey
posted on 17/8/15 at 08:40 AM Reply With Quote
I don't like number 4
Build Blog
Build Photo Album
jambojeef
posted on 17/8/15 at 08:51 AM Reply With Quote
Uprated box.
That engine in a nice light 7 should be a hoot!
Geoff
Paul Turner
posted on 17/8/15 at 08:56 AM Reply With Quote
Option 5. Speak to Steve Perks in Redditch. 01527 894232. He will sort out your existing gearbox with a long input shaft and for a small extra sum fit a better first gear. All for a fraction of the cost of a BGH or similar.
lsdweb
posted on 17/8/15 at 09:55 AM Reply With Quote
Thanks all
I'll give Steve Perks a ring today.
Ta
Wyn
posted on 17/8/15 at 10:06 AM Reply With Quote
5. Get a Caterham 6-Speed Box
6. Get a Caterham 6-Speed Box
7. Get a Caterham 6-Speed Box
8. Get a Caterham 6-Speed Box
9. Get a Caterham 6-Speed Box
10. Get a Caterham 6-Speed Box
11. Get a Caterham 6-Speed Box
12. Get a Caterham 6-Speed Box
13. Get a Caterham 6-Speed Box
14. Get a Caterham 6-Speed Box
15. ...
It's Evolution Baby!
lsdweb
posted on 17/8/15 at 10:59 AM Reply With Quote
15. ...
I don't suppose you have one....
femster87
posted on 17/8/15 at 12:36 PM Reply With Quote
I love option 4 1st dibs for £500
lsdweb
posted on 17/8/15 at 12:38 PM Reply With Quote
Add a zero on the end and it's yours!
Ugg10
posted on 17/8/15 at 01:04 PM Reply With Quote
What about the RX8 option that the classic ford boys seem to be using at the moment, forget 1st gear and you then have a close ration 5 speed box. Just needs an adaptor plate, input shaft spline and spigot bearing are ford compatible.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
lsdweb
posted on 17/8/15 at 01:10 PM Reply With Quote
Thanks Ugg
I did think of that but the tunnel is too small for it I believe.
posted on 17/8/15 at 02:51 PM Reply With Quote
Sorry - no Cat box.
adithorp
posted on 17/8/15 at 03:20 PM Reply With Quote
It'd be a shame to give up on the K-series but... "Go BEC" is always the correct answer.
I'd have sworn Scootz had one when he said that.
http://jpsc.org.uk/forum/
snapper
posted on 17/8/15 at 05:44 PM Reply With Quote
Sierra V6 engined cars have the long input Type 9
Ratios are better
V6. Straight 4
1st 3.36. 3.6
2nd 1.81. 1.97
3rd 1.26. 1.36
4th. 1. 1
5th 0.85. 0.87
I eat to survive
I drink to forget
Ugg10
posted on 17/8/15 at 06:10 PM Reply With Quote
Thanks Ugg
Lots of pics and comparisons with type 9 in this thread if you need to check sizes.
http://www.turbosport.co.uk/showthread.php?t=500016
Paul Turner
posted on 17/8/15 at 07:03 PM Reply With Quote
Ratios are better
V6. Straight 4
1st 3.36. 3.6
2nd 1.81. 1.97
3rd 1.26. 1.36
4th. 1. 1
5th 0.85. 0.87
Both the 4 cylinder and V6 box have a 0.82 5th as standard. The 0.85 and 0.87 are the ratio's you get form BGH, Quaiffe and others.
matty h
posted on 17/8/15 at 08:23 PM Reply With Quote
I will hopefuly be doing this match up of engine and gearbox soon including caterham bellhousing, although I am seriously looking at rx8 box probably 5 speed as it seems to have more useable 1st gear over the more expensive 6 speed.
Can a adaptor not be machined up to fit on the end of the shaft and welded on.
Matty
dilley
posted on 17/8/15 at 08:51 PM Reply With Quote
And the rest!!!! S2000 with gear indicator is 8k!!!!
lsdweb
posted on 17/8/15 at 08:55 PM Reply With Quote
Shortstroke Rover K Series.......
[Edited on 17/8/15 by lsdweb]
lsdweb
posted on 17/8/15 at 09:07 PM Reply With Quote
Matty
Is the five speed similar to the six? Does it have the same splines etc to match up with the Ford clutch?
Ta
Wyn
femster87
posted on 17/8/15 at 09:16 PM Reply With Quote
Wyn, the input shaft can be changed, had similar done for my K series installation. Would have loved your engine bought a 1.8 few months ago.
I will change the ratio whilst you are at it though. I bought a locost with a standard type 9, I have to say after years of having either a straight cut close ratio and the 6 speed gearbox, the standard box feels really odd and sluggish
[Edited on 17/8/15 by femster87]
lsdweb
posted on 18/8/15 at 08:09 AM Reply With Quote
Thanks Femi
I'd love to go for a proper competition 'box but can't justify it right now!
I've just bought an RX8 gearbox to see if it'll fit in the tunnel - I don't think it will but I'll give it a go just to satisfy my curiosity!
Regards
Wyn
COREdevelopments
posted on 21/8/15 at 09:49 PM Reply With Quote
Hey Wyn, sorry can't help with your query but out of interest how wide is your transmission tunnel? Is it similar locost book chassis? I am looking at a different gearbox due to a problem with my ae86 t50 box.
Thanks Rob
lsdweb
posted on 27/8/15 at 10:38 AM Reply With Quote
Hi Rob
Sorry for the delay in replying - we've just got back from holidays.
The box is way too big! The tunnel on the Striker is tiny and the box is over an inch wider at a point just in front of the gear lever. I can take some measurements if you want. You're more than welcome to borrow the Mazda gearbox to try in your Luego.
Regards
Wyn
rdodger
posted on 27/8/15 at 05:28 PM Reply With Quote
15. ...
This!
<<  1    2  >>
