Author: Subject: Sylva mojo info
MsD
posted on 26/8/15 at 07:11 PM Reply With Quote
Sylva mojo info
Evening chaps,
As we all know one kit car isnt enough so ive acquired a sylva mojo....
Its got inboard shocks, a toyota 4age engine and a de-dion rear set up. This is about all i know but i think its an early one. Its in a state of disrepair, not road registered and doesnt have any bodywork... but i like a challenge!
My intentions are to fit a 20v 4age, full cage and make my own custom bodywork with the idea of competing in sprints hillclimbs!
Does anyone have any info/ specifications/ build diarys i can have a browse through? I will take aome pictures when possible as pics are always good!
Thanks, Mark.
Ugg10
posted on 26/8/15 at 07:22 PM Reply With Quote
Jpsc (jeremy Philips sports car club) would be a good place to start. Iirc a fair bit of the mojo is similar to the j15 and j16 chassis wise so if you like the seven look or the fury/phoenix look then there may be bodies you can modify to fit. For the latter search jenko on here for a tasyty looking car with a similar chassis.
[Edited on 26/8/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Ugg10
posted on 26/8/15 at 08:07 PM Reply With Quote
http://www.mymojo.co.uk
http://www.madinventions.co.uk/mojo/WhatIsIt.htm
http://sylvamojo.blogspot.co.uk/2007/03/rolling-chassis-wheels-on.html
Forgot about this one, mini body on a mojo chassis
http://s450.photobucket.com/user/MyMiniMojo/media/MiniMojopickinguptheChassisfromSylv.jpg.html
http://myminimojo.m.webs.com/site/mobile?dm_path=%2Fintroduction.htm&fw_sig_site=35999868&fw_sig_partner=webs&fw_sig_permissions=none& fw_sig_social=1&fw_sig_access_token=cf78388b75b509392a0966a5c1a1394921fefc86&fw_sig_is_admin=0&fw_sig_session_key=a21532db22d0e9003852b873 e88c9c0077805674618c5615fd286a1bb63ed4d7-35999868&fw_sig_potential_abuse=1&fw_sig_locale=en-US&fw_sig_permission_level=0&fw_sig=e9a34a 1a30f7ac00c69675dcd14daeec&fw_sig_url=http://myminimojo.webs.com/&fw_sig_premium=0&fw_sig_api_key=522b0eedffc137c934fc7268582d53a1&fw_ sig_tier=0&fw_sig_time=1440619420692&fb_sig_network=fw#2131
Jenko
posted on 26/8/15 at 08:13 PM Reply With Quote
As mentioned, similar chassis to J15......Checkout my build blog, you may find something useful. Best of luck.
MY BLOG - http://westfieldv8.blogspot.co.uk/
inkafone
posted on 26/8/15 at 09:51 PM Reply With Quote
Mojo SE is the slightly longer version and has the same chassis bar the outriggers as the J15. I believe the Fury Menace had a similar chassis. A modified J15 body could be made to fit or standard body on a lengthened wheelbase. Making your own body panels would be very time consuming, better to find something that already looks decent. Ebay sometimes has unfinished projects - e.g. here
Ugg10
posted on 26/8/15 at 10:46 PM Reply With Quote
Not sure about the menace as the engine was longitudinal and sat slight to the side of the driver with the passenger pushed forward. A bit like a toned down version of the mev atomic.
Another body that may be able to be made to fit is the pell Genesis or the spire gt but probably not as easy as the j15.
MsD
posted on 9/9/15 at 05:12 PM Reply With Quote
Thanks for the help/ advice guys.
I was flicking through an old cop of ckc the other day and your build diary was in there Jenko, a nice tidy build and a bit of inspiration.
Ive read through a couple of the posted build threads- lots of good info, cheers!
Re the bodywork- Ive done a bit of fibreglassing/ repairing on my previous project so im not averse to getting stuck in, but if I can find something that it roughly the right dimensions/ look then it makes life easier!
Ive finally got some pictures of the chassis as it is;
[img]Thanks for the help/ advice guys.
Re the bodywork- Ive done a bit of fibreglassing/ repairing on my previous project so im not averse to getting stuck in, but if I can find something that it roughly the right dimensions/ look then it makes life easier! So if anybody has something lurking in a dark corner of the garage, let me know..
And help on what the uprights/ gearbox is would be great!
Cheers, Mark.
