Author: Subject: Clutch cable help
Steve ads
posted on 3/9/15 at 01:42 PM Reply With Quote
Clutch cable help
Hi guys I'm after a bit of help with a clutch cable I'm changing gear boxes and the clutch fork is now on the opposite side so I need a longer cable can anyone recommend a place that does custom one or one that's got a big of length to it I can't use the original cable as its too short and the new box had a hydraulic clutch
Cheers Steve
[Edited on 3/9/15 by Steve ads]
posted on 3/9/15 at 03:34 PM Reply With Quote
Better to fit a mastercylinder go hydraulic
[Edited on 3/9/15 by britishtrident]
gremlin1234
posted on 3/9/15 at 04:01 PM Reply With Quote
often worth seeing what RHD / LHD versions use.
edit. just re-read your original, and now agree with BT just go hydraulic.
[Edited on 3/9/15 by gremlin1234]
posted on 3/9/15 at 06:43 PM Reply With Quote
What engine/ gearbox combination do you have? If your still using the Xflow then I would suggest having a look at the Burtonpower website , they list clutch cables for Ford along with the lengths . Failing that try Speedy Cables for a custom cable or convert to hydraulic
Steve ads
posted on 3/9/15 at 07:44 PM Reply With Quote
Thanks for the info I'm mid way through a xflow rx8 gear box combo got a few bits for the hydraulic swap just wanted info on a cable if it don't work without swapping peddle box
Dingz
posted on 3/9/15 at 10:59 PM Reply With Quote
Sierra cosworth ones are long, 2wd and 4wd slighlty different lengths but over 2m, transit is long too.
went on and on.
posted on 4/9/15 at 06:24 PM Reply With Quote
Sierra and later Transit cables use an automatic adjuster quadrant so not easily manually adjusted
