Author: Subject: Zetec RWD & Supercharger setup
Neilwilson
posted on 13/9/15 at 06:37 PM Reply With Quote
Decided to change engine choice so have:
2.0 Blacktop (NGD code)
Shortened sump
Bosch green injectors
5 speed Type 9 Gearbox
Complete wiring loom
ECU
CVH Starter
Engine mounts
ST170 intake manifold lower for ITB's
Great setup - all you need is there. £450 - may separate if there is enough interest.
Also have:
Jackson racing inlet manifold to allow an Eaton M45 to bolt ontop - £150
Vortech V1 supercharger no end play, with brand new complete bearing and seal kit - £800
[Edited on 13/9/15 by Neilwilson]
kingster996
posted on 13/9/15 at 07:23 PM Reply With Quote
What ECU?
I used to be indecisive, but now I'm not so sure
Neilwilson
posted on 13/9/15 at 07:50 PM Reply With Quote
It has TEEM written on, there maybe other numbers that I can check in the morning.
furryeggs
posted on 13/9/15 at 08:11 PM Reply With Quote
How much would you like for the sump? if you'll split it?
Neilwilson
posted on 13/9/15 at 08:31 PM Reply With Quote
Already have provisional interest on the sump, if it's still here if/when splitting I will let you know.
Neilwilson
posted on 14/9/15 at 02:38 PM Reply With Quote
Neilwilson
posted on 14/9/15 at 02:40 PM Reply With Quote
Neilwilson
posted on 15/9/15 at 07:26 PM Reply With Quote
Now listed on the bay of thieves
http://www.ebay.co.uk/itm/-/262050352436?
100792taz
posted on 16/9/15 at 10:32 PM Reply With Quote
parts
have you still got the manifold
Neilwilson
posted on 17/9/15 at 06:24 AM Reply With Quote
Yes i still have it mate
[Edited on 17/9/15 by Neilwilson]
Neilwilson
posted on 18/9/15 at 02:32 PM Reply With Quote
2.0 Blacktop (NGD code) with inlet & exhaust manifold approx 70k - £150
Shortened sump - £50
Bosch green injectors (803's) - £30
Type 9 Gearbox - £175
Complete wiring loom & ECU - £45
CVH Starter - £25
Zetec Engine mounts - SOLD
ST170 intake manifold lower for ITB's - £30
Jackson racing inlet manifold - SOLD
Vortech V1 supercharger no end play, with brand new complete bearing and seal kit - £750
Neilwilson
posted on 3/10/15 at 04:44 PM Reply With Quote
Bump for the weekend
Neilwilson
posted on 4/10/15 at 02:24 PM Reply With Quote
2.0 Blacktop (NGD code) with inlet & exhaust manifold approx 70k - provisionally SOLD
Shortened sump - provisionally SOLD
Type 9 Gearbox - provisionally SOLD
Complete wiring loom & ECU - provisionally SOLD
CVH Starter - £25
Vortech V1 supercharger no end play, with brand new complete bearing and seal kit - £700
[Edited on 4/10/15 by Neilwilson]
J90rdn
posted on 26/10/15 at 08:36 PM Reply With Quote
Ggrrrrrrr - would have had most of that off of you. Looking for engine, box, wiring etc etc
Let me know if for some reason sales fall through.
terryathome
posted on 27/10/15 at 01:16 PM Reply With Quote
Injectors
Are the injectors high impedance and 14mm?
If so would like first dibs please.
Terry
