Author: Subject: those small nut and screw thing - what are they called
posted on 16/9/15 at 08:22 PM Reply With Quote
Im looking for a couple of the double height nuts at the end of which is a threaded section, about M4 size.
They are found on computer connectors e.g. graphics card, the screw part holds the socket in place, the nut allows the connector to be screwed in.
Hope that makes sense.
What are they called and where to buy?
Staple balls
posted on 16/9/15 at 08:26 PM Reply With Quote
standoffs?
dave_424
posted on 16/9/15 at 08:29 PM Reply With Quote
Look for VGA stud
daniel mason
posted on 16/9/15 at 08:31 PM Reply With Quote
Like these?
Pack of 10 x DB Stud/Bolt/Nut Serial/9/25/Parallel/VGA/SVGA for Cable/Cord/Wire
AndyW
posted on 16/9/15 at 08:32 PM Reply With Quote
Like these?
That's the exact link I just found.....
coyoteboy
posted on 16/9/15 at 08:44 PM Reply With Quote
You're looking for female jackscrews, or for metric threads - pcb standoffs. standoffs are usually brass but stainless and alu ones are available.
[Edited on 16/9/15 by coyoteboy]
Madinventions
posted on 16/9/15 at 09:13 PM Reply With Quote
Farnell stock M4 standoffs in a range of lengths; http://uk.farnell.com/ettinger/05-14-203/spacer-m4-20mm-length/dp/14670 30
View my band website:
http://www.shadowlight.org.uk
coyoteboy
posted on 16/9/15 at 11:47 PM Reply With Quote
Just be wary, the brass ones are like butter - not good for anything more than attaching PCBs together.
Go to Mouser UK and get either Stainless or Alu from RAF hardware:
http://uk.mouser.com/search/refine.aspx?N=4292891802+17652579
We use these in products that survive launches on ICBMs
